12-31-2018, 01:37 PM | #1 |
Simple Questions I can't find an answer for
72 Blazer w/ TH350 transmission- When changing the transmission dipstick 1- can I swap the tube out for a later one with a grommet seal without any problem? and 2- does the fluid need to be drained to do the swap or can I swap it while it's full? I was caught without a pan when swapping the speedometer bullit. Don't want to repeat that. Thanks!
72 Chevy 2WD Blazer |
01-01-2019, 03:36 AM | #2 |
Re: Simple Questions I can't find an answer for
You will need a drain pan under it you are going to spill some when the dipstick is removed.
01-02-2019, 04:26 PM | #3 |
There are good chemicals on the market to remove oil stains from your driveway, if you choose not to use a pan
I'm using dipstick from Locarr
