01-02-2019, 01:14 PM | #1 |
Light problem
Almost have all my kinks worked out but when I’m driving at dark and go to kick on my highbeams my dash lights go out but if I keep them on low beam the lights will stay on. Any idea what is causing this?
01-02-2019, 02:27 PM | #2 |
Re: Light problem
Check your ground wires 1st, then double check. Dash should have a ground wire clip, and a couple built into the harness.
01-02-2019, 09:54 PM | #3 |
Re: Light problem
90% of electrical gremlins are grounding problems.
01-04-2019, 11:57 PM | #4 |
Re: Light problem
Check the plug at the dimmer switch. These are nortorious for getting corroded or the switch is bad.
01-05-2019, 10:35 PM | #5 |
Re: Light problem
X2! Just replace my dimmer. Chased wiring and eventually checked the dimmer. It was full of corrosion. $12 bucks at NAPA and problem solved.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
