Old 01-09-2019, 08:01 PM   #1
Bearhawg
Bearhawg's Avatar
Aftermarket Tach Install Fail
What could I have touched in these three areas that would have caused my system to stop charging? I installed a small aftermarket tach with a very simple setup. Green tach wire, red power wire, white dial lighting wire and a black ground wire. Easy-peasy. I secured the tach to the column with big zip ties. I know nothing about chasing electrical gremlins.I removed everything and through the tach in the "I'll do it later" drawer. I'm thinking about starting my rewiring project six months early to solve this.
Any suggestions? Thanks!
Fuse panel where I tapped into the switched power (radio fuse) and dash light fuse and tried to attach the ground wire on the horn relay mounting screw. I ended up using a screw on the bracket used to hold the column in place at the firewall.
Name:  Fuse panel 1a.jpg
The HEI distributor where I tapped into the tach connecter
The ratty engine harness where I wrapped two frayed wires (yellow and green) that I found in the process.
Name:  engine harness 2.jpg
Bearhawg is offline   Reply With Quote
Old 01-09-2019, 09:04 PM   #2
Shinysideup
Shinysideup's Avatar
Re: Aftermarket Tach Install Fail
What amperage does that tinfoil fuse blow at?
Also, your new issue is the alternator? What voltage running and at rest?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 01-09-2019, 09:20 PM   #3
Bearhawg
Bearhawg's Avatar
You have an excellent point about the tinfoil. The PO installed and I honestly I’ve been afraid to touch it. How do you test the alternator output. I have a multimeter. Will that work? I’m new to all of this and everything is a learning opportunity. Thanks for the input. I need all the help I can get.
Old 01-09-2019, 11:08 PM   #4
saxart
saxart's Avatar
That looks like 15amp tin-foil to me.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 01-09-2019, 09:57 PM   #5
Shinysideup
Ok, how do you know its not charging?
Simply test battery voltage engine off and then running, at the battery terminals. Should be 12.5, then 13.5-14.5 running.
As for the tinfoil, replace it with correct size fuse for that circuit. That could burn down the truck if wires overheat with no fuse.
._____________
Old 01-10-2019, 07:28 AM   #6
rpmerf
rpmerf's Avatar
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 01-10-2019, 04:11 PM   #7
jcwren
What's that heavy red wire with the black connector in the first picture go to under the hood? I've got one of those, but it's not connected to anything, and it doesn't show up on the schematics.
I'm thinking MAYBE the guy who started restoring the truck added it for an electric choke, but I'm not certain.
jcwren is offline   Reply With Quote
Old 01-10-2019, 04:44 PM   #8
Bearhawg
Bearhawg's Avatar
Believe it or not that goes to an intermittent wiper control on the dash. I’m sure it worked for about 30 seconds after it was installed. There is a power port (BAT) on the HEI distributor that I tapped for my electric choke conversion.
