Old member
I have been looking at these for off and on for over a year now. I finally found a full set with owners manual and won them for a whopping $35.00!
With the 56 Bel Air,64 SS Impala ,67 Ramp and 71 C-10 all having round lights I figured it was worth it plus it's a cool piece of automative history!Now I just need to learn how to use them to get the most out of my light's. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Vintage Lev-L-Lite Model B4 Headlight Aimers
Heck yea. Nice.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
WOW! I have (maybe still) one of those parts, the little device in the last picture. I never could figure out what it was. I always thought it was some kind of surveying tool, but every surveyor I worked around had never seen one. Last time I saw mine, my grandkids were playing with it. I do have the case (what's left of it) and some directions:
![]() ![]() ![]() ![]() I'll have to look around and see if I can find the actual tool. ![]()
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Moderator
![]() ![]() Join Date: Aug 2011
One of the members did a write up on his experience - http://67-72chevytrucks.com/vboard/s...d.php?t=429063
#5 | |
Old member
![]() Quote:
Thanks great write up for sure. I saved it for future use. Anybody tell me what this part is? I flipped the picture and blew it up on paint and it looks like a ground level piece to take care of the floor if it's not level. Maybe. ![]()
Old member
I found the owner manual on the net! It goes through the whole process of the alignment! Has pictures and all you need to align your lights with the kit.
![]() http://secure.hmswarehouse.com/TECH/hoppy/HP1003B.pdf
Those are what we used to use in the assembly plant.
One of the last steps before rolling of the end of the final line. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Old member
I got them yesterday and plan to use them today trying to get the lights on the ramp truck done. I carried the ramp over to my friends shop yeterday and installed his new wheels & tires on his all factory Lemans with 3 dueces that he built 4 speed Hurst edition. I'll get pictures today as I start the tilt column change out in the ramp truck today.
Old member
Does anyone know how the light meter is suppose to work? I can't find any info about it. I put it in front of the Impala lights but it doesn't do anything. I hooked to my volt meter to read continuity and it moved a little and beeped so I know it's all connected.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-16-2019 at 11:40 PM. |
