![]() Join Date: Mar 2012
rear sway bar info
Gents,
Any benefits to this with stock ride heights? or will this even work? 63-72 Rear Sway Bar 7/8" Coil Spring Trucks 1963-72 Rear 7/8" sway bar for 2 wheel drive coil spring equipped trucks. Includes all necessary mounting hardware. Some modifications are required to install if vehicle is stock height. https://gmcpauls.com/pictures/63-72rearcoilswaybar.jpg Curious about what modifications needs to work??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Moderator
![]() ![]() Join Date: Aug 2011
Re: rear sway bar info
Nothing more than drilling holes after you square the unit on your trailing arms. I think CPP and POL all make/sell them as well.
#3 | |
dose some one have a pic of it installed? I am curious where i have to drill holes??
I installed the solid rectangular tube trailing arms, not to keen on drilling into them
Moderator
Installed:
http://67-72chevytrucks.com/vboard/s...7&postcount=36 POL web site - https://www.performanceonline.com/19...r-Coil-Spring/
Thanks Master Chief ,
One more question did it come with dimensions or instructions on where to place and drill?
Moderator
Yes it did.
