Junior Member
![]() Join Date: Nov 2018
Reduction gear starter
Hey guys, anyone know for absolutely sure where to get a gear reduction starter that will fit a BB 402, automatic 400, 168 tooth flywheel? I just bought one from NAPA that the paperwork said would fit,it didn't. So, now I'm stuck with a $270 starter that is useless to me. If someone knows where to get the right one, and maybe the part number, I would appreciate the information.
Re: Reduction gear starter
Powermaster 9526 - Powermaster XS Torque Starters
Powermaster 9612 - Powermaster Mastertorque Starters |
Junior Member
Thank you sir. I think I saw those on Summit. Have a good day!
Another option is the gear reduction from a gm 8.1 big block. Get the starter bolts from a dealer. You need 1 of each bolt. Total cost is less then $7 bucks and fit the best.
Part Numbers
AJC |
#5 | |
![]() Join Date: Feb 2019
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Junior Member
Thanks, AJC
At the body shop.
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-15-2019 at 10:22 AM. Reason: Pn add |
Junior Member
I'll check it out. Thanks.
At the body shop.
Have them on 3 of my 4 vehicles two 454s and one 400 sb and it starts with 36° initial timing.
" That didnt make it any newer " " Dont antique the equipment " |
Who Changed This?
![]() Join Date: Jan 2013
Looks like you now have it under control, but I bought mine at a local speed shop and luckily got it right the first time. A good counter person makes all the difference in the world. It doesn't seem to engage a lot of the flex plate (which is the original, at 217k miles). The flex plate will be replaced soon.
Junior Member
I took it back. I got a lady salesperson who knew very little, and I now own an expensive wheel chock. To the guy with all the tooth counts and mounting locations, thanks, but that doesn't make this starter fit my motor.
#12 | |
AJC |
#13 | |
Whatever parts store sold you the wrong part and wouldn’t take it back sux.
