01-20-2019, 09:07 AM | #1 |
Centerline of Front Axle???
Doing a conversion from 2wd to 4wd on a C30 frame - Is the centerline of the existing 2wd axle the centerline of the top ball joint? Hope that makes sense. I am marking the frame before I cut out all the 2wd stuff
Thanks guys
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
01-20-2019, 02:16 PM | #2 |
Re: Centerline of Front Axle???
gotta figure in caster angle. might be slightly in front of the top ball joint.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
01-20-2019, 02:19 PM | #3 |
No need to mark the centerline, the front spring hangars mount the springs which determine the axle centerline
01-20-2019, 04:36 PM | #4 |
X2 with Randy, get the hangers correct, the axle will follow.
