01-29-2019, 11:46 AM | #1 |
4L80 vss signal
Hello all,
Has anyone converted to an electronic trans (OD) from the original 350/400 turbo? If yes, what did you do about the VSS? I am running a 4l80 with a MSD controller. The motor and the trans run fine but my idle has been erratically high. A guys at "gearheadEFI" said the original PCM needs the VSS for some reason to idle right. If you made this swap, how did you hook up the original VSS to the 4l80? Thanks, Chris |
01-29-2019, 11:48 AM | #2 |
Re: 4L80 vss signal
What engine are you running? What you're describing is something that happens in LS swaps but in that case, you just connect the VSS to the ECU/PCM. I am guessing you're running the older TBI setup?
What vehicle is it in? Thanks |
01-29-2019, 11:49 AM | #3 |
Re: 4L80 vss signal
01-29-2019, 05:28 PM | #4 |
Re: 4L80 vss signal
I believe that means the TH400 you had would have been one of the late TH400 which had a VSS. You may need to use a new DRAC or adapter box from jagsthatrun.com - if you already used your VSS to send to the MSD control box, you may have to use a splitter similar to what was used for the electronic gauges to split between the speedometer and the ECM.
If I was in your shoes, I'd be calling MSD since you're using an MSD controller rather than a newer PCM and harness which seems to be most common in this swap. That said, typically without VSS engines tend to idle low or die as you come to a stop rather than idle high. I'd be testing the IAC and TPS as part of my diagnosis. |
01-29-2019, 05:52 PM | #5 | |
Re: 4L80 vss signal
I called MSD after I made the post and was told the VSS signal from the 4l80 is the same as the 400T. He said i need to splice the OEM ECM to the same wires the MSD uses. I hope it is that simple. |
01-29-2019, 05:54 PM | #6 | |
Re: 4L80 vss signal
It would make sense since the 4L80E is simply the evolution of the TH400 and by the time the TH400 received a VSS the 4L80E was in development and starting to be put into trucks shortly thereafter. If you can simply tap the wire for the ECM signal then thats all the better! |
01-31-2019, 10:01 PM | #7 |
Re: 4L80 vss signal
I had time tonight to connect the OEM VSS wire and I can not find any connector or wire near the transmission without a home.
I have complete wire diagram book and it shows a connector with pink/blk, blk, brown blk being the ground, pink blk coming from the fuse box and brown being the signal. I believe the vss gets its signal from the back of the speedo,, it has the little green box there and none of those wires exit the firewall. Could the green vss box be bad??? thanks, Chris Last edited by chris989; 01-31-2019 at 10:42 PM. |
01-31-2019, 11:20 PM | #8 |
Re: 4L80 vss signal
I have a 1990 V2500 Suburban that I installed a 4L80E in. You need to use the signal out of the transfer case and not the signal out of the back sensor of the transmission. The 4L80E 4x4 model does not have the wheel at the rear sensor to activate the VSS.
