Old 01-29-2019, 06:50 PM   #1
Shawn5800
Shawn5800's Avatar
Control arm bushing question
I think I answered my own question but why on earth do these all in one bushings and casings not fit from LMC? It seems like they are supposed to be welded in place of what my arms have now.
Can I pull the bushings out of these cases or should I send them back?
Shawn5800 is offline   Reply With Quote
Old 01-29-2019, 07:21 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Control arm bushing question
Send them back and buy urethane replacements that use the old sleeve already in place , The one you have in your hand is the replacement if you want to press the old sleeve out and press the new sleeve/ bushing in . in .
Old 01-29-2019, 07:30 PM   #3
Shawn5800
Shawn5800's Avatar
Damn, thanks for that! What I waste 😂 same bolts should fit the urethane replacements right?
Old 01-29-2019, 08:13 PM   #4
jcwren
Yes, same bolts. I recently did mine. If you're having trouble getting the rubber bushings out, hose them down with PB Blaster and let them sit for a while. I used a large C-clamp and a couple pieces of flat metal to press the old ones out and the new ones in.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 01-29-2019, 08:15 PM   #5
Shawn5800
Shawn5800's Avatar
Thanks!
