02-04-2019, 04:04 PM | #1 |
1960 truck fan shroud
Is there a shroud that will fit a 60 with the stock size radiator? The truck has a small block in it and a flex fan and no shroud (solid mount fan with no shroud is factory...right?).
I have has great luck with a shroud and a fan clutch on all of my other older vehicles. Suggestions?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-04-2019, 09:24 PM | #2 |
Re: 1960 truck fan shroud
With all the mods I went with the Flex-a-lite Black Magic 180 (3300cfm). With out controller, used one from Speedway Motors that piggy backs temp sender. Used original tabs. You can make a box style or tri 5 chevys use same style shroud.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 Last edited by LVPhotos; 02-04-2019 at 09:42 PM. |
02-04-2019, 10:51 PM | #3 |
There are three different factory fan shrouds for '60-'62 trucks.
The first looks like a '58-'60 passenger car "Barrel" type shroud. The second is more of a full-shroud that covers the whole core. The third is wider and has an area "notched" to clear lines for automatic transmissions. They show up here every once in a while, and show up on Ebay too. I don't know if there is a difference between 6 and 8 cylinder applications, or even if there are more versions.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
02-05-2019, 11:56 AM | #4 | |
02-05-2019, 04:33 PM | #5 |
02-14-2019, 02:40 PM | #6 | |
Check The Champ, Demonstrator
There is a difference between 63-66 6 and 8 cylinder. The 8 cylinder you can find , the 6cyl seems only came with A/C equipped trucks and are impossible to find. The medium duty and heavy duty 6 cyl shrouds are not the same as the light duty..
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
02-05-2019, 01:21 PM | #7 |
Try the 55-57 Chevy Bel Air. They look to be same radiator.
https://www.danchuk.com/ItemForm.aspx?Item=16626A
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
02-05-2019, 08:43 PM | #8 |
The 63-66 factory style shroud adapts well to the 60-62's.
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827 62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583 |
02-13-2019, 01:45 PM | #9 |
Any pics?
02-13-2019, 08:26 PM | #10 |
Take a look at the link in my sig. Page 3 and 4 I believe.
02-05-2019, 09:34 PM | #11 |
i have a barrel style shroud if U interested??
02-13-2019, 09:02 PM | #12 |
will try to post pics later 2day !!!
02-13-2019, 10:17 PM | #13 |
But Found Her 25yrs Later!
A couple related threads :
. http://67-72chevytrucks.com/vboard/s...ghlight=Shroud . http://67-72chevytrucks.com/vboard/s...ghlight=Shroud
02-14-2019, 12:22 AM | #14 |
having trouble posting pics will try again 2marrow!!
02-14-2019, 03:22 PM | #15 |
The truck I have is a long water pump. Will that make a difference without changing everything over to short?
02-14-2019, 04:56 PM | #16 |
Thats no problem. Mine was a long water pump also.
02-14-2019, 07:08 PM | #17 |
So you added the 63 and later side panels to a truck with a 60-62 radiator and then trimmed the shroud to fit?
02-14-2019, 10:25 PM | #18 |
see pics
02-16-2019, 02:01 PM | #19 |
02-14-2019, 10:45 PM | #20 | |
If you decide to go this route and need more fitment details, just ask.
02-19-2019, 06:02 PM | #21 |
This is what I would do. Clean, uses OG parts and simple.
