02-05-2019, 07:39 AM | #1 |
71 c10 temp sensor
My temp sensor requires a15/16 to remove but tested it wih an ohm meter and has conduit. Where can i find the bullet style connector, is it a special type of connector or is is it something found at napa?
02-05-2019, 11:53 AM | #2 |
Re: 71 c10 temp sensor
It has continuity when tested? Is that what you meant to say? When tested with a meter or DVOM, it read 0 ohms?
You can just open up a regular female spade connector to work for the time being and order a connector from just about anywhere I suppose.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-11-2019, 06:49 AM | #3 |
I bought the connector I installed it but I'm not getting any reading on the gauge is just one wire or does this have a ground wire?
02-05-2019, 12:21 PM | #4 |
If it looks like a little 'T' on top, that's a "GM Single Wire Coolant Temperature Sender" connector, and you can get those at The Repair Connector Store for around $5/ea.
The 'T' connector is used on a temperature senders for gauges. It's a different connector if you have idiot lights.
1970 C10 LWB Stepside 1971 Dodge Dart 1993 Buick Roadmaster Estate Wagon |
02-05-2019, 04:42 PM | #5 |
thank you, i appreciate your help. that was the info i needed. found it because the detailed picture and description on that web site, NAPA has it
02-11-2019, 06:49 AM | #6 |
I got the wire connector for it I installed it but I'm not getting any reading on the gauge is it just a single wire or does this have a ground?
02-11-2019, 07:37 AM | #7 |
no ground wire.
02-11-2019, 07:53 AM | #8 |
If you wrapped the threads of the sensor in teflon tape, you may not have a ground. It's grounded through the block.
