Old 02-05-2019, 04:54 PM   #1
69Tom
69Tom's Avatar
U bolt prices
Can anyone explain to be the discrepancy in rear axle U-bolt prices? Mine are rusty as all heck and I'm sure I'll have to cut them so I'm trying to be prepared for when I have to reinstall things.
For instance:
https://www.brotherstrucks.com/60-72...ctinfo/UBOLTS/
https://www.classicparts.com/1960-72...info/74%2D751/
Any U bolts you'd recommend? I'm open to suggestions.
Thanks.
69Tom is offline   Reply With Quote
Old 02-05-2019, 05:15 PM   #2
Lanman1972
Lanman1972's Avatar
Re: U bolt prices
I can't help with an explanation, but I bought mine from Manes Truck Parts $17.95 each.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 02-05-2019, 05:27 PM   #3
jcwren
Re: U bolt prices
I'd say the Brother's bolts have a black oxide finish, and you're paying for that.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 02-05-2019, 05:32 PM   #4
weim55
Re: U bolt prices
Any shop that specializes in suspension work for heavy trucks can make U bolts of any size on the spot. Prices have always been very reasonable for any that I've had made.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 02-05-2019, 05:30 PM   #5
rcazwillis
Re: U bolt prices
Classic looks like a single bolt. Brothers is a pair and has a lock washer. That only explains about half the cost.
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-05-2019, 05:52 PM   #6
TheRocket
Re: U bolt prices
I bought mine from Wes at Classic Heartbeat. He has them made locally. I am very pleased with them. They should last.
TheRocket is offline   Reply With Quote
Old 02-05-2019, 06:08 PM   #7
sick472
sick472's Avatar
Re: U bolt prices
Black oxide coatings are pretty cheap, like a buck or two per u-bolt given that you supply some quanity to the coater. It cetainly does not account for the big price diffence. I would paint them regardless, so oxide finish means nothing to me. Go with the more affoardable ones or check around locally as mentioned.
Side Notes:
Not all u bolts are equal...some are longer for adding lowering blocks, but that still should not cost much more than stock
Axle u-bolts are not intended to be re-used. I know they can be, I have done it, but probably should not have. The finer threads are of higher presision than regualar ole' bolts and distort under proper torque. Consider your rusty bolts trash and get some new ones.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-05-2019, 07:13 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: U bolt prices
Not at all sure but I'd guess $65/pr = USA, ~$30/pr = China.
Just a gut feeling. I could be wrong.
Old 02-05-2019, 07:40 PM   #9
AussieinNC
Moderator
AussieinNC's Avatar
Re: U bolt prices
LMC U bolt, two nuts and two washers...$14.95 each....standard length..
30-0386
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 02-05-2019, 07:53 PM   #10
69Tom
69Tom's Avatar
Re: U bolt prices
30-0386
They're definitely on my list, as I have a couple other items I want to get from there (I usually don't use them but they have a couple things I want).
Thanks all for the replies.
Old 02-05-2019, 08:36 PM   #11
swb4me
Re: U bolt prices
If you pay the shipping, I'll give you this set that came in my early classic enterprises drop kit. I replaced my rear trailing arms and that kit included a set, so I didn't use these. They've been sitting on the self in my garage for 2 years, so they have a little flash rust on them. I think they'll fit in one of the usps flat rate boxes.
swb4me is offline   Reply With Quote
Old 02-05-2019, 08:47 PM   #12
AussieinNC
Moderator
AussieinNC's Avatar
Re: U bolt prices
Cant beat the price!
Thats what I love about this forum...its full of nice folk always willing to help....
2012 Chevy Equinox
Old 02-05-2019, 11:54 PM   #13
69Tom
69Tom's Avatar
Re: U bolt prices
Hey, thanks a ton! Just PM me on how to pay. Much appreciated!
Old 02-07-2019, 12:53 PM   #14
GMCPaul
Re: U bolt prices
Well in regards to grade and pricing we carry the grade 8 made in usa u-bolts for coil spring trucks and sell them with the heavy duty washers and wide nuts for $50.00 a pair. They cost us twice what the imported grade 8's sell for and over 3 times more than more than the imported grade 5 cost. So the grade of bolt, nut and washer along with source play a large role in the pricing of these. My understanding is that most of the shops bend the grade 5 unless you actually specify you want grade 8.
Paul Jr. @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 02-07-2019, 06:02 PM   #15
69Tom
69Tom's Avatar
Re: U bolt prices
Cool. Thanks for all the info guys. Very helpful. And many thanks to swb4me for the bolts.
Old 02-07-2019, 08:25 PM   #16
Re: U bolt prices
Why buy from specialty vendors when your local parts store or spring shop can take care of your needs? Probably be cheaper. That's what I do. I only buy the model specific parts unavailable elsewhere from the 67-72 GM Truck vendors.
