Old 02-06-2019, 01:22 AM   #1
Captainfab
60-66 Nut
Trailing Arm Mounts
A member PM'd me about the dimensions for installing the trailing arm mounts on a later model differential for a '63-'66 but I wanted to post that info here for everyone's benefit. This will actually be correct '63-'72.
The front holes of the trailing arm mounts are 39" center to center. The rear holes are 41.250" center to center. The pinion angle is up 14 degrees. If the trailing arm mounts are level the face of the pinion yoke will be at 76 degrees.
Old 02-09-2019, 02:08 PM   #2
Blue666(2)
Re: Trailing Arm Mounts
Thaks CaptainFab!
Blue666(2) is offline   Reply With Quote
