Old 11-24-2003, 05:28 AM   #1
77K20
Dash lights not coming on
Sometimes when i turn my lights on, my dash lights won't come on. My turn and bright indicators light up, but nothing else. And when I turn my brights on, the indicator goes off. I used to be able to remedy this problem with a little "tap" on the dash, but not anymore. Any suggestions on what to do?
Thanks in advance for any and all info.
2-Knee
77K20 is offline   Reply With Quote
Old 11-24-2003, 09:45 AM   #2
maineiac
Sounds like you might have some corrosion on the printed wiring that is on the back of your cluster about the only way to get at it is to pull the whole cluster out and try cleaning it up mine was green in several places did some cleaning and now works fine.
Steve
maineiac is offline   Reply With Quote
Old 11-24-2003, 02:35 PM   #3
apstguy
LED King
apstguy's Avatar
The main connector plug may be slightly out of placke or the wires are loose. Try wiggling the the main connector. It may also be your headlight switch or a short somewhere. Lots of wiring to check so start now!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 11-24-2003, 04:54 PM   #4
crossy
Oh,you can't buy that new
crossy's Avatar
I posted this exact problem 2 weeks ago about my 85. I know dashes VERY well and i have tried everything mentioned plus a few other things , like replacing the headlight switch,and mine won't come back. If you positively find the problem let me know.
my circuit and wiring are very clean and in great shape. I also reached up and made sure the connector was firmly in. Nuttin- it's real cool :-( when i turn on the 4 ways some of the gauges do a little dance for me. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 11-24-2003, 05:50 PM   #5
77bowtie
does the interior light work when you turn the switch on ?
77bowtie is offline   Reply With Quote
Old 11-24-2003, 06:21 PM   #6
maineiac
Crossy
That still sounds like a printed cicuit problem try removing the lights that go to your blinkers and see what it does. I may have one laying around I could send you if you want it.
Steve
Old 11-24-2003, 08:10 PM   #7
Jonboy
Slots go on anything!
high beam switch?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
