Old 02-12-2019, 08:45 PM   #1
jamie72
jamie72's Avatar
over drive in a 71
whats the best route in putting an over drive in my 71 k20,i think the 410s and 33 will too low in a daily driver.
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 02-12-2019, 09:24 PM   #2
renegade6
Re: over drive in a 71
I have a 700R4 in both of my trucks. Big difference with overdrive and a lock up converter.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 02-12-2019, 09:35 PM   #3
mongocanfly
mongocanfly's Avatar
you have auto or manual trans?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-12-2019, 10:16 PM   #4
sweetk30
sweetk30's Avatar
play with this . you can change speeds at the bottom click the window and put in what you want .
http://www.grimmjeeper.com/gears.html
th350/400 - 4.10 - 33" tire @ 70mph = 3087 rpm
700r4 ----- 4.10 - 33" tire @ 70mph = 2046 rpm
sm465 4speed - 4.10 - 33" tire @ 70mph = 2922 rpm
nv4500 5speed - 4.10 - 33" tire @ 70mph = 2192 rpm
hope this helps you a bit .
try and find your engines best vacuum reading cruising and match the rpm with what you find to your new range and this will help you stay in the power curve sweet spot . if to high or low its no good as your maxed or at the bottom fighting to get to the sweet spot .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-13-2019, 05:36 AM   #5
jamie72
jamie72's Avatar
auto.
jamie72
member #807
www.antlertalk.com
Old 02-13-2019, 05:38 AM   #6
jamie72
jamie72's Avatar
most of the tranny guys around here don`t recommend them as they say they are weak and it takes a lot of $$ to build them up to hold??
jamie72
member #807
www.antlertalk.com
Old 02-13-2019, 12:15 PM   #7
kwmech
4L80e and move the engine forward to install it
Old 02-13-2019, 01:01 PM   #8
Orange Crate
Orange Crate's Avatar
I am partial to this OD, HA!
http://67-72chevytrucks.com/vboard/s...d.php?t=750764
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 02-13-2019, 01:26 PM   #9
Orange Crate
Alright already, I'll try to be helpful this time. This chart shows a TH350 or TH400 (3 speed) 1:1 ratio with the convertor locked and the effects of tire size and final drive ratio on engine RPM (add a couple hundred RPM if the convertor is unlocked). Most manual five speeds have the 1:1 ratio at 4th gear (like the NV4500) and then 5th gear is the OD ratio usually somewhere around .7:1 or .73 or even a little closer to 4th like .8:1. You can use this chart to find your engine RPM at 1:1 (3rd gear for auto or 4th gear for manual) then take that RPM and multiply it by .7 or .73 or .8 or whatever OD your new trans has. That's easy enough right? Sorry for the resolution but it is the only picture I have of this. I think a 700R4 has OD in 4th (it still has 1:1 in 3rd) but I do not know what ratio it is maybe close to .73 or so. Maybe someone else can add that.
Old 02-13-2019, 02:25 PM   #10
sweetk30
sweetk30's Avatar
how do you lockup the convertor on a non lockup trans ? ? ?
convertor unlocked is a little over 200rpm extra from all i have read.
my no's were from the link i provided in my post above . its a SUPER calculator that lets you pick from a list of trans options / t-case options / or enter your own and enter axle and tire dia or by size . then you can edit the results in the rpm's or mph box's by clicking and changing them .
Old 02-13-2019, 04:51 PM   #11
Orange Crate
I said I would "try" to be helpful, I didn't say I actually "would" be helpful!
Old 02-13-2019, 06:35 PM   #12
sweetk30
sweetk30's Avatar
please its all good . we cool .
Old 02-14-2019, 12:23 PM   #13
renegade6
GM actually had a TH350C that had a lock-up converter.
Brandon
Old 02-14-2019, 12:45 PM   #14
sweetk30
sweetk30's Avatar
oh i know . only ever had my hands on just 1 and it was in a parts truck . do you remember the twin pitch convertor th400 i think it was ?
Old 02-13-2019, 01:43 PM   #15
Orange Crate
Sorry I think this chart was written at 60 MPH, I can't find it for sure now. Makes sense when compared to sweetK30 numbers.
Old 02-13-2019, 02:17 PM   #16
Orange Crate
Ok, I found my old post from 2013 and the chart was written at 65MPH but I think that may be wrong compared to sweetK30s numbers above. Maybe sweetK30 can shed some light on where his numbers be comin' from. Also the chart is divided into three categories. The rpm highlighted in black are
optimum for the tire size and ratio combination. These will most closely
give you the best overall drivability. If you're looking for a ratio that
will give better fuel economy for highway driving at the expense of some
acceleration and overall performance, choose a ratio in the yellow shaded
area. If you're looking for a ratio that will improve acceleration and
towing power at the expense of some fuel economy, choose a ratio in the blue
shaded area.
Old 02-14-2019, 05:37 AM   #17
jamie72
jamie72's Avatar
thanks guys, appresite all the help
jamie72
member #807
www.antlertalk.com
Old 02-14-2019, 02:18 PM   #18
rpmerf
rpmerf's Avatar
For OD with an auto trans, you are looking at a 200R4, 700R4, 4L60E, or 4L80E.
A 700R4 is what would had come in a truck 82-92. They are hydraulic. A 200R4 is a weaker version, but they can be built up.
A4L60E / 4L80E is what would had come in a truck 93-??. They are very similar to the 700R4, except that they are electronic controlled. 4L60Es are considered to be weak, 4L80Es are considered to be bullet proof. If you go with either of these, you will need a standalone TCM to control the transmission.
My years may be 1 or 2 off...
To me, having a TCM kind of goes against the point of having an old truck, but that's up to you.
Trying to gauge how well a transmission will hold up can be difficult. One person may call the transmission a hand grenade, while others have had them last over 200K. If your mostly on the street and cruising, it will last longer. If your towing, off roading, or racing, you may opt for something stronger. Look around at write up, what others have done, how different setups have held up.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 02-14-2019, 05:07 PM   #19
El Dorado Jim
I have a sm465 manual trans in mine with 4:10 's. I am going to put a Gear Vendor overdrive in mine, I already have it, just need to buy the adapter
El Dorado Jim is offline   Reply With Quote
Old 02-19-2019, 06:48 PM   #20
Yukon Jack
Yukon Jack's Avatar
Wait, was some one offering beer???
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-19-2019, 07:27 PM   #21
Bigdav160
Bigdav160's Avatar
They are hydraulic [shifted]. A 200R4 is a weaker version, but they can be built up.
No 4x4 versions of the 200-4R although you could go with the divorced transfer case option.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-19-2019, 08:47 PM   #22
LEEVON
Moderator
LEEVON's Avatar
700r4 is not the strongest trans, but it's fine for your stock-ish big block. You should talk to a competent trans guy...a few upgrades make them handle some power fine. I have quite a few built, they're usually about $900-1300 with upgrades plus converter, crossmember, dipstick, fluids, cable, etc. Never had any trans builder complain about them or not warranty them and I've never lost one. Last one I did is currently behind a pretty rowdy cammed 5.3L, it does the job well and fries tires at will. Good cores are getting harder to find though, I snatch them up whenever I can. Passed on a few 4x4 versions and picked up a couple of 2wd's recently.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 02-23-2019, 07:29 PM   #23
74CustomK20
74CustomK20's Avatar
For a good recommendation, tell us what you do with the truck, and how you drive. Do you prefer an auto, or roll your own gears?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 02-25-2019, 07:04 PM   #24
jamie72
jamie72's Avatar
its going to be a daily driver, and tow 3500lbs about 2-3 times a yr. i`d be fine with a stick, but ineed to go auto so if need be the wife can drive it.
jamie72
member #807
www.antlertalk.com
Old 03-01-2019, 02:02 AM   #25
'63GENIII
'63GENIII's Avatar
Precisely the reason I run an NV4500...the thought of my wife driving the Brick!
Kidding aside, we have an 04 Yukon XL Denali 6.0 urban assault grocery getter with a 4L65E. I think the car is 7 or 8k lbs and we tow a 4500# boat and have our 4 kids, wife's stuff and boat stuff. Never weighed it but its heavier than the truck when loaded and towing. I had a transmission built by TransStar a few years back with a couple of better parts on Clinebarger's recommendation. This transmission has been awesome. Id probably run it behind the old 396 that I had in the truck.
The 454 that i have now is a different story. Id feel a little weird not having a 4L80 behind that. It makes a more torque than the LQ9 in the Denali and way more than the 396 ever could.
I think that stand alone controllers and harnesses can be had for either electronic transmissions as well.
You've got a few choices which is good.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
