![]() Join Date: Aug 2004
Motorhome Tilt Column
$250 shipped in lower 48
Please respond in thread only per board rules, first "I'll take it" gets it. Selling a motor home tilt column. From an early 80s GM chassis Move the NSS down and it's a bolt-in for your 67-72. There's some threads about this mod. Tilt mechanism is tight. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. The bottom bearing was greased and is in good shape. The shift indicator bulb was replaced and tested OK, it has the green shade on it. Shifter arm end (inside column) is good, pivot is average Turn signal and tilt levers are driver quality Turn signal switch is tight and cancels as it should Turn signal has the flat connector The gray illumination wire is long enough to be spliced well under the dash Includes a long pigtail for the Neutral Safety/Reverse switch This column is good for a driver, it's clean but has some scratches and normal wear It would be a great candidate for a scuff and shoot if you wanted to make it really nice.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 02-15-2019 at 09:50 PM. |
Re: Motorhome Tilt Column
Pics
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
More pics
Saturday bump
Ttt
I can't believe no one has grabbed this yet great deal. I just bought one before Christmas that cost more . Mine was pulled out of a shed and then I had to go through it. Fit just like a factory tilt and only takes about 30 min to move the neutral switch. I will tell my buddy about it should fit a 65 also?
I suspect it will fit the 60-66 trucks, but I haven’t messed with one in years so I don’t know.
Would you take $225 shipped?
I can meet you in the middle at $235, shipping is high for these.
I'll take it.
Sold to short n wide 72
Got it.
Thank You |
