Old 02-17-2019, 08:04 PM   #1
rcazwillis
Bed Grounding - light issue
No lights are working in the bed. They worked two weeks ago, but not today. The power is getting to the plug. Has to be a grounding issue. How does the bed get grounded? Is frame contact the only source of grounding?
Zane's 71 Build
rcazwillis is offline   Reply With Quote
Old 02-17-2019, 08:08 PM   #2
68 P.O.S.
Re: Bed Grounding - light issue
Here's a good thread that will help you http://67-72chevytrucks.com/vboard/s...d.php?t=422234
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 02-17-2019, 08:20 PM   #3
Sparky dave
There is a ground strap from bed to frame and frame to battery you can check resistance with a multimeter. Or check voltage on lighting wires but try put your ground probe on the bed. If nothing try ground probe on frame and lastly use a length of wire to put your ground probe to the battery ground. This will tell you where the break in the ground path is back to the battery. Hope you can follow my descriptio, good luck
Sparky dave is offline   Reply With Quote
Old 02-17-2019, 08:25 PM   #4
landarts
landarts
I just went through this about a week ago. I removed the light housing, then you will see two clips that the screws go into, remove the clips, clean the metal on the bed where the clips go, if the clips are rusty clean or replace. If the housing is dirty or rusty clean that also. Reassemble and you should have better ground situation which will allow the light to work properly. This is what I did and it worked for me. My housing, bulbs, and wiring harness was brand new, but when I painted truck the clips were painted, once I cleaned the metal of paint it grounded. Good luck!
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 02-19-2019, 08:12 PM   #5
Myoldtruck
Myoldtruck's Avatar
I added a battery cable from the engine block to the frame. Then added a number 6 green stranded wire with wire lugs, at the rear of the frame to rear of bed under the truck. You can get all that at Lowes.
Myoldtruck is offline   Reply With Quote
Old 02-19-2019, 10:25 PM   #6
rcazwillis
Picked up a grounding cable at parts store. Grounded frame to bed. Lights work...problem solved.
Zane's 71 Build
