Old 02-20-2019, 01:57 PM   #1
demian5
demian5's Avatar
1965 Rear Brake line bracket on Diff
Hi -
I need a picture of the bracket that holds the brake line T to the diff on a 65 12-bolt. An image of where the hose connect to the line on the frame would be great too.
Thanks!
Working on a short bed with a 12-bolt.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-21-2019, 05:48 PM   #2
demian5
demian5's Avatar
Re: 1965 Rear Brake line bracket on Diff
So nobody has a 63-66 they could get a picture for me?
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-21-2019, 06:40 PM   #3
cwcarpenter98
cwcarpenter98's Avatar
Here is an old pic that I found when I was doing the brakes. Is this the bracket you were asking about?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 02-22-2019, 01:07 AM   #4
Captainfab
60-66 Nut
1960-64 is going to be different than '65-'72. The pic posted by cwcarpenter98 is the '65-'72 style.
Old 02-23-2019, 12:54 PM   #5
cwcarpenter98
Thanks Captainfab for confirming what I thought was the case. The PO swapped in a different rear end, and just heated and bent the trac bar to make it fit. No wonder I had the bar snap on me a couple of years ago
Christian Carpenter
Old 02-22-2019, 11:44 AM   #6
demian5
demian5's Avatar
Yeah i have a 65 rear diff and am using 65 brake lines etc. It doesn't have a welded on bracket.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 02-22-2019, 12:33 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
My 64 used the panhard bar bracket on the rear housing for the brake line tee.
