![]() Join Date: Sep 2018
14" Rotors touching lower control arms
Hi, I've installed a Ridetech Streetgrip kit and now trying to install a Wilwood 14" brake kit but the rotors are touching the lower control arm. Any ideas. I also replaced the control arms with a set from LMC. The spindles were in the kit from Ridetech. I need to start a build thread, I'm going with a LT4 / 8L90 from SpeartechThanks in advance.
71 C10 SWB |
Re: 14" Rotors touching lower control arms
Welcome aboard! Yes... please start a build thread! I’ve seen it a common thing to trim the lower control arms for allowing 15” rims to fit without rubbing, but I can’t say that I’ve seen it done because of big brake rotors. I don’t see why it would be a problem.
Brian
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
![]() Join Date: Feb 2016
Grind it or heat and beat. Either way will work. The down side of both ways is that nice coating on the control arm will have to be touched up. Grrr!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Moderator
![]() Join Date: Jun 2017
LMC lower arms are renowned for being thicker in the lower ball joint mount area causing your contact issue. They work ok with up to 12 " rotors...that's my experience with them....
Would suggest some aftermarket arms rather than grinding on the arm itself... Anyways...keep safe.... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
I would "gently" move it with a hammer. You might be able to get a large crescent wrench on it & bend it enough.
Thanks guys, To be safe I've decided to bite the bullet and get Ridetech's strong arms with the coilovers .
71 C10 SWB |
