11-25-2003, 11:21 AM | #1 |
Bucket Seats
I have a set of 67-68 bucket seats that are basically shot,they need new foam and of course re-covered.I was wondering if there is any way to convert these to the shape of the 69-70 seats? Any help would be appreciated.Thanks
11-25-2003, 11:25 AM | #2 |
Resident Curmudgeon
Anything is possible but do yourself a favor and trade with somebody that has the style you want. The expense involved is not worth it and the results would probably be sub-par. If I had a set of the 69-70 style, I'd trade you. The style you currently have is generally more sought after, and the style you want are easily obtainable.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-25-2003, 12:32 PM | #3 |
Yes I would love to have another set of the 67/68 seats.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-25-2003, 12:48 PM | #4 |
What's the difference between the buckets over the years? Height, bracketry, shape, console style? I'm kinda keeping my eyes out for a set of the buckets with the flip down arm rest / center seat. How do truck seats differ from blazer / sub buckets (if at all?) Thanks....
11-25-2003, 04:14 PM | #5 |
Project Junkie! Fishing Poor!!
We now have all new 67-68 Bucket seat foams available in our website. Not available untill now. $199.95 per set and a set consist of 1 seat bottom and 1 seat back. email me if you are interested. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-25-2003, 04:31 PM | #6 | |
Resident Curmudgeon
The 67/68 style (on left) is a 40/20/40 setup and bolts to a tubular frame. The center console/seat can be flipped up to reveal a storage area and can be flipped down for an armrest. The drivers side only adjusts. Burbs used similar setup except w/o the center seat back. Dodges used same setup but different frame to mount. 67 used a wide pleated pattern, whereas the pleats in 68 were spaced closer together. These are the hardest to find and cost more. They are IMO more comfortable and are a more versatile design. In 69, the more modern setup of 2 separate buckets and a center console were used. 69-70 used a single scroll pattern (center) and 71/72 used a dual scroll pattern vinyl (right). The seats were the same in burbs, Blazers, and trucks, except Blazers and burbs had plastic backings and Blazers used a flip-forward pass seat bracket to allow access to rear seat. Trucks used fixed passenger brackets (I assume Burbs did too), and in all vehicles only the driver side adjusted. Blazers also had utility buckets which look like mini bench seats (i.e. not contoured for fanny). These had steel backings, not plastic. They used same seat brackety however. All consoles 69-72 had rectangular holes for the seat belt buckles. Cup holders did not appear until 77 or 78. Other than the cupholder change, consoles from 69 to late 70's early 80's are the same. On the consoles, Chevys had a bowtie emblem (blue 69-72, gold 73-up), GMC's used the red GMC emblem. 73-up lowback buckets are almost identical to 69-72 style. The back's corners are a bit more squarish and the vinyl patterns/colors were different. Throw a period-correct cover on them and you'd be hard-pressed to tell the difference. The brackets used 73-up buckets will not work however as the floor contours are different.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 11-25-2003 at 04:41 PM. |
11-25-2003, 04:37 PM | #7 |
Resident Curmudgeon
Here is a 73-up interior
11-25-2003, 04:46 PM | #8 |
If I understand this right.....67-68 buckets were all on the same track below, like a bench seat. The center '20' section could be a seat, armrest or insane cooler if you wanted? Then in 69, the buckets came with individual brackets for drivers and passenger side? What happened to the flip-up / flip-down console? I've got an ad showing the 40/20/40 scheme with no plastic seatbelt holding contraption. I'm looking for the correct 69 buckets that still had the center seat. Was that style only correct for 69, or was it a 69-70 deal? Individual brackets? How does the center 20 section mount? Thanks Jeff....you're a world of info.
11-25-2003, 04:52 PM | #9 |
Resident Curmudgeon
Can you scan the ad? What I described is all I've seen personally. Could what you descibe be a motor home setup or something? I am by no means the final word on anything
11-25-2003, 05:28 PM | #10 |
computer illiterate
i have a set of buckets without the brackets ill swap yah?
if your interested pm me
72 2wd blazer 72 swb 4x4 |
11-26-2003, 09:00 AM | #11 |
Nevermind....I'm a moron. I looked again, and it is the individual buckets with the center console; ashtray and seatbelt holes. Each seat has 1 scroll pattern down the center (CST model).
