03-05-2019, 12:40 AM | #1 |
ideas on wire routing
I am building a 1971 show truck and it was partially started when I bought it. My question is the previous owner smoothed the firewall and other than the power brake booster and emergency brake cable there are no visible holes, they installed vintage air in it and put the bulkhead fittings in the side of the cowl to be hidden under the fender.
I am constantly trying to figure out where to run the wiring and speedometer cable out of the cab and I have a couple of places in mind to drill holes in the floorboard and use rubber grommets to get the underhood wiring into the engine bay and also out to the rear lights ect.. I was just wondering if any of you had experience with this and if you had a good location and/or likes/dislikes on where you did it? |
03-05-2019, 01:19 AM | #2 |
Re: ideas on wire routing
Don't know if this helps, but here's a 71 A/C cab.
If you need a closer shot just ask. The cab is bare.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-05-2019 at 01:25 AM. |
03-05-2019, 02:32 AM | #3 |
thanks, good info.
i'm just wondering where the best place is to cut hidden holes for wires and speedo cable under the truck so you don't see wires when hood is raised. |
03-06-2019, 11:03 AM | #4 |
03-05-2019, 01:31 PM | #5 |
Right above the trans tunnel isn't a bad place to hide holes.
Brandon 63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne 57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380 72 K20 Long bed stepside (wife's) 72 K20 Long bed 396 (flip or keep...?) The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476 |
03-05-2019, 04:12 PM | #6 | |
03-06-2019, 01:24 AM | #7 |
I can take pics and text them or e-mail them to you, if you tell me how.
I would like to post them here for everyone but I haven't had much luck on forums like this in the past posting pics and it has been a few years since I used photobucket. |
03-06-2019, 11:27 AM | #8 |
I'd be interested in the heater,A/C lines
03-09-2019, 11:23 PM | #9 |
Sent pics in a text, see p.m.
03-15-2019, 01:04 AM | #10 |
will try again--1st try failed to post pic
03-15-2019, 01:15 AM | #11 |
lets see if pics post now?
03-15-2019, 01:25 AM | #12 |
one more inside of cab lines. I don't like them being there but the firewall looks better?
