03-07-2019, 03:49 PM | #1 |
Steering Column Wire Harness
It’s been 7 years since I took it apart and some days it’s a struggle finding all the parts I squirreled away. I swear I remember a 8” or so harness piece that plugs into the column harness and then into the main harness. I’m hoping someone can confirm or deny this so I can either stop looking or tear the garage and shed apart 1 more time. Thanks
03-07-2019, 04:21 PM | #2 |
Re: Steering Column Wire Harness
There is an adapter that plugs the newer turn switch harness into the older connector. The new replacement TS has a flat connector while the original is curved. Sometimes it comes with a new switch. It can be bought at most specialty parts stores.
George |
03-07-2019, 04:25 PM | #3 |
I’m not trying to convert anything, everything is OEM.
03-07-2019, 04:53 PM | #4 |
This adapter is a short harness like you describe. I figure that's the piece you can't find.
George |
03-07-2019, 05:49 PM | #5 |
Are you talking about this?
1985 C10 shortbed, current project. Member of the Upstate SC GM Truck Club. |
03-07-2019, 05:54 PM | #6 |
Is this what you are looking for?
03-07-2019, 06:07 PM | #7 |
I do not have any flat terminals. End from the main harness is curved. End fron the steering column is curved. I’m not try to “adapt” a newer harness.
03-07-2019, 06:54 PM | #8 |
03-10-2019, 07:25 PM | #9 |
There is no short harness off the steering column. The 2 curved plugs go straight together.
03-11-2019, 12:02 PM | #10 |
X3, you are not missing anything. That pigtail you have comes off the turn signal switch for signals and hazard lights as well as the horn. I just replaced mine and that is all the wiring there is, no extra connector. There is not a lot of slack in the harness, but it isn’t stretched extremely tight either.
1971 Custom/10 - 350/3 speed, Orange/White roof |
