Old 03-07-2019, 03:51 PM   #1
Expalo
1970 c10 350 dies as soon as i hit 40 mph
Ok so i just bought this truck. The vin states its a chevy c10 3/4 ton chassis. But it is the full time 4wd. It just had a transmission rebuilt before i bought it. It has the chevy 350 with a th350 behind it. I have replaced fuel filter and spark plugs (they were fouled pretty badly). I also timed the engine to a 10* advance. I was gonna rebuild the carb but i broke one of the carb mounting bolts and didnt want to risk breaking the others until i knew i could replace the whole intake and carb if i broke them all. It has brand new battery and cables as well. What is going on is at first before timing it and replacing spark plugs it would run at idle and low speeds just fine but then i would hit 25 mph and it would bog down and die. I timed it and replaced spark plugs and now i can go all the way to 40 and it just bogs down and dies. Its as if The fuel just stops sending to the carb. I dont have much experience with carbed engines and just want some more experinced opinions on what is going on.
Expalo is offline   Reply With Quote
Old 03-07-2019, 04:58 PM   #2
Wrenchbender Ret
Re: 1970 c10 350 dies as soon as i hit 40 mph
Sounds like the sock on the fuel pickup in the tank is plugged up. You say you replaced the filter in the carb. Sometimes someone puts an inline filter in the line from the tank to the pump. Check to see if there might be an aux. filter underneath.
George
Wrenchbender Ret is offline   Reply With Quote
Old 03-07-2019, 05:41 PM   #3
Expalo
I actually replaced the inline fileter there was no filter in the carb. And i dont think it is the stock carb either i dont know if that makes a difference, it is still a 2bbl carb.
Old 03-07-2019, 05:44 PM   #4
Expalo
George
Do i have to pull the fuel tank to clean sock on the fuel pickup?
Old 03-07-2019, 06:20 PM   #5
geezer#99
geezer#99's Avatar
No!
But do some other things first.
Disable the ignition so it won’t start when you crank it over.
Pull the fuel line off the carb, stick it in a quart jar and crank it over. It should fill the jar in 30 seconds or less.
Let us know how that works.
Also post some pics of your motor for us.
Old 03-08-2019, 10:50 AM   #6
Expalo
Originally Posted by geezer#99 View Post
No!
What is the best way to disable the ingnition?
Old 03-08-2019, 10:57 AM   #7
geezer#99
geezer#99's Avatar
Depends on your distributor type.
Points type just pop the coil wire off.
If hei unplug the power clip from the cap.
Pics of what you got would help.
Old 03-07-2019, 09:24 PM   #8
garyd1961
Could be a crack in your fuel line sucking air. I had it happen to me once on a 69 442. It would run fine at low speeds but if I brought it off the line it would go 3 or 4 car lengths and cut out.
garyd1961 is offline   Reply With Quote
Old 03-07-2019, 11:47 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
What carburetor, and what ignition (stock points or HEI)? There are many things that can cause this. Let's just say you creep up on 40 MPH. Does it still happen, as opposed to a full throttle run up to 40 MPH?
~Steven
Simi Valley, CA
Old 03-08-2019, 10:56 AM   #10
Expalo
Im pretty sure its a rochester 2bbl carb. And i think it does have the hei distributor. Yes if i creep up to 40 it still dies vs doing a full throttle pass. No matter how i feather the gas as soon as i hit 40 it basically shuts off. Sometime when i lef off the gas for a couple seconds and then tap the gas a couple times the engine comes back to life but runs rough for a little.
Old 03-08-2019, 10:51 AM   #11
Expalo
I was thinking about replacing the fuel lines anyway so maybe i will just replace them and not worry about looking for a crack.
Old 03-10-2019, 04:59 PM   #12
68Gold/white
That carb looks like it may not have ever been off engine, or apart. Could be part of problem...If it's had any ethanol gas run through it, that could be a problem...
68Gold/white is offline   Reply With Quote
Old 03-10-2019, 05:24 PM   #13
Expalo
I have a buddy who took a quadrojet off of his old 350 he has the carb and intake he will sell me for 50$. Is that worth is to buy that and put it on vs trying to rebuild the one thats on it?
Old 03-10-2019, 05:50 PM   #14
geezer#99
geezer#99's Avatar
That might be a choice after we diagnose your problem better.
Give us some more pics. With the air cleaner off. Show us both sides of your carb. And the bolt you mentioned is broken.
Old 03-10-2019, 06:34 PM   #15
hjewell2
hjewell2's Avatar
weights are stuck under the rotor and causing the motor to die out, .
hjewell2 is offline   Reply With Quote
Old 03-12-2019, 01:18 PM   #16
Expalo
Ok got some more pictures. Ill be working on it today and tomorrow as this is my weekend. After that one bolt broke i did not try and take any of the others out. Would it help if i got a video of what was happening as it dies?
Old 03-12-2019, 02:11 PM   #17
geezer#99
geezer#99's Avatar
That missing bolt shouldn’t be a problem. There were 4 on your carb. Originally on older intakes there were only 2 bolts holding the carb on.
Sure a video won’t hurt.
Your pics don’t help much.
Try some that aren’t closeups.
Old 03-12-2019, 05:20 PM   #18
Expalo
Ok hopefully these are better
Old 03-12-2019, 05:48 PM   #19
palallin
Carb swallowed some of that orange goo holding the jury-rigged air cleaner hold-down?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-12-2019, 06:07 PM   #20
geezer#99
geezer#99's Avatar
Much better pics!
Some very laughable stuff you got.
Carb linkage and cobbled air cleaner stud to name a couple.
First thing I’d do is put in more timing. Bump it up to 15 initial.
If that doesn’t improve it then check the fuel pump output.
Old 03-12-2019, 06:14 PM   #21
Grumpy old man
Grumpy old man's Avatar
A can of carb cleaner would probably help a lot , Plugs ,wires,etc, . Join one of the local car clubs in your area .They could help you out with the hands on stuff .
Here are a few .
https://www.google.com/search?q=+Gra...firefox-b-1-ab
Old 03-12-2019, 07:02 PM   #22
Expalo
I did just replace the plugs havent done wires yet but that is ok the list along with new belts and to tighten up that altenator braket it tends to shake a lot. The only reason have not joined a car club is because i will be moving here in a couple months and didnt want to get involved just to leave. And i have some experience just not with gas engines. I tend to stick with diesel. This is my first real gas project. As it happens i am hopfully in the next year or so gonna swap a 12 valve cummins into it. Haha but need a runing truck before then.
Old 03-16-2019, 06:00 PM   #23
Expalo
So i have no idea what happened or anything but i did no other work and drove it today and it is working fine drove 55-65 just fine without bogging out
Old 03-12-2019, 06:57 PM   #24
Expalo
Much better pics!
Haha ya its a project thats for sure. Ok ill add some more timing and we will see how it goes.
