03-10-2019, 10:26 AM | #1 |
Keep the original gas tank?
We are working on a 1954 Chevy truck / s10 swap. We are also rebuilding a new engine (350). As you can imagine the cost is growing at each step! We are trying to decide if we keep the existing gas tank and leave it behind the seat (its a new tank) or dump some more money into a tank underneath the bed.
Has anyone keep the original tank in their restore and not regretted it?? Thoughts... |
03-10-2019, 01:37 PM | #2 |
Re: Keep the original gas tank?
I'm keeping my original tank location. I'ts the safest place. I also need the spare tire location. I don't want the fender mount spare tire and do not want to run without a spare. In some states a spare tire is required. I'm going to have a fuel cell made to fit behind the seat with duel fuel compartments for a short run down the strip.
03-10-2019, 03:34 PM | #3 |
No, it REALLY isn't. Years ago I remember seeing a story on "60 Minutes" about the in-cab tanks. Over decades the rubber hose between the tank neck and the neck on the body becomes very hard & brittle. In even a relatively mild accident, the tank is jarred and the tube doesn't just tear, it shatters and gasoline is sprayed around the cab. Back in those days - 1970's - these trucks were still in common use as daily drivers with people smoking, etc. they told the story of people getting severely burned/killed. I totally get the value of having the spare the original location. In mine, I'm just going to carry some Fix-A-Flat. Not a great solution but better than a tragedy.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! Last edited by Dan in Pasadena; 03-10-2019 at 03:43 PM. |
03-10-2019, 04:43 PM | #4 | |
03-10-2019, 05:27 PM | #5 |
That 60 min deal was on squares with saddle tanks. That was finally called b.s. when GM investigated it. The story is on utube. I see these guys putting their tanks in the back taking out the rear crossmember to make them fit? So in a rear end crash all you have is a cheesy bumper protecting the tank from impact no thanks. Chances of getting rear ended anymore is pretty high when they run 6 inches off your bumper!
03-10-2019, 06:13 PM | #6 |
The center of the vehicle is the most protected location in an impact from any direction.
1951 Chevy Panel Truck |
03-10-2019, 07:15 PM | #7 | |
I'm talking about the Task Force trucks. The AD's that had the saddle tanks were very protected. But (I THINK?) that worked because they came with a straight six cylinder and the exhaust ran back on the opposite side of where they placed the tank.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-10-2019, 07:17 PM | #8 | |
03-10-2019, 02:23 PM | #9 |
I like the tank behind the seat it is higher then in the frame and fuel is free flowing to the fuel pump .
03-10-2019, 03:18 PM | #10 |
im on the opposite side...I don't want a gas bomb in the cab with me...mines going under the bed...
03-11-2019, 12:45 AM | #11 | |
On the fuel cell thing. I think you will find that will not pass tech at any drag strip with the cell inside the passenger compartment. Stock gas tank maybe but not a fuel cell as you have then moved to a different level.You would have to have a firewall between the cell and the rest of the passenger compartment to pass tech.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-11-2019 at 12:52 AM. |
03-11-2019, 01:12 AM | #12 | |
03-11-2019, 02:33 AM | #13 |
if its an s10 frame why not use the stock s10 saddle tank? and you can even keep the spare in the rear location if you want.
03-11-2019, 08:28 AM | #14 |
I kept my tank in cab. Wishing I had moved it to under the frame as all my new interior now smells of gas due to a fuel leak I had sing up on a rubber hose. I have fuel injection so a return hose was ran into the cab.
I will relocate in the future. |
03-11-2019, 10:05 AM | #15 |
i'm on the "get the fuel out of the cab" side of the fence. I have been around lots of these and other old trucks with the tank in the cab. they usually smell like old gas inside. read the label on any fuel pump at any fuel filling location and it will say something about the vapors being cancer causing. the tank needs to vent and it is the cap doing that for you right outside the window. there are multiple places for a leak to happen. if it is an s10 frame swap then why not just use the stock s10 tank and be done. the tank also comes with a built in fuel pump. the stock tire location is still available then as well. sure, you will need to fab a fuel filler. just like jodoh says and he should know, it's like a job for him, building AD trucks sitting on s10 frames. he has it down to a science and knows what works and what doesn't.
your truck and your decision so you do what you want. be safe though and think about future changes and what you may want down the road. safest place for a tank, in my opinion, is mid-frame on the inside of the frame rail. can't be all bad if a lot of newer trucks are built that way. safe from front or rear impact and also pretty safe from side impact on the side the tank sits on. I am sure there is a youtube out there that will contradict, there always is. yes, you will have to do some different things for cross members and exhaust routing and also fab a tank filling method but still, likely the safest option and you can still run it down the track if you want to. |
03-11-2019, 12:00 PM | #16 |
This seems to be a question where you have advocates for both sides. Either way, it needs to be done as safe as possible. When I get to the point I am thinking of sealing and enclosing the area my '57's stock tank is in and venting it separately than the fuel vent. Not much different than what a guy building an early '30's coupe/roadster or muscle car guy does when putting the tank in the trunk. I am not a fan of tanks clear at the back of a truck as that seems to be a first place for damage in a rear ender. Side tanks seem hard to find a place and tank to fit. I have considered a larger Moon style tank in the front of the bed. Not a fan of filling over the bed side and taking up bed space tho but the jury is still out on that one.
Tags |
fuel tank, original |
