Old 03-10-2019, 07:59 PM   #1
KevinR
While the 250 is pulled...
Changing out some gaskets on my 70 250 and decided it’d be easier out of the truck. In any case, with them engine out, what else would you guys be looking at or replacing?
KevinR is offline   Reply With Quote
Old 03-10-2019, 09:35 PM   #2
jocko
jocko's Avatar
Re: While the 250 is pulled...
Check or just go ahead and replace the clutch, pp, release bearing and pilot bushing and at least check the flywheel for heat cracks, replace if necessary (assuming you have a manual trans). Check brake lines while it's easy to see em.
Old 03-10-2019, 09:48 PM   #3
KevinR
Thanks Jocko. Clutch flywheel etc being replaced. U joint and center support being replaced. Planning on water pump and radiator based on age and condition. Debating if I should pull the bed. Engine was running fine when parked last fall but if I have it pulled I want to make sure I cover all my bases.
Old 03-10-2019, 10:06 PM   #4
saxart
saxart's Avatar
If you're pulling the oil pan for a new pan gasket, it might be smart to remove one of the crankshaft bearing caps to see what kind of shape the mains are in if you don't know the history of the engine. In my case this was the deciding factor in NOT putting anymore money into my old SBC (i.e. getting the heads cleaned up, new gaskets, etc.) as the main bearings were discolored and had scratches in them even though the engine ran pretty well.
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 03-11-2019, 06:55 AM   #5
GRX
GRX's Avatar
While the engine is out and they're easy to get to. Core plugs ... core plugs ... core plugs.
(often erroneously called freeze plugs)
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-11-2019, 08:59 AM   #6
KevinR
Got it, I’ll add core plugs to the shopping list and bearings to the inspection list!
Thanks for the help guys, as suggestions roll in I’ll keep updating my list
Old 03-11-2019, 10:05 AM   #7
Steeveedee
Who Changed This?
Steeveedee's Avatar
You know it! They're a lot more fun to replace with the engine out.
~Steven
Simi Valley, CA
Old 03-12-2019, 10:24 AM   #8
KevinR
Any thoughts on head gasket replacement? If yes, any thoughts on head bolt replacement? The ARP studs are $120 and seem a little overkill for a straight six freshening up. Can I just get grade 8s the same length as the bolts I pull?
Old 03-12-2019, 09:21 PM   #9
wpavlis
Front shocks, any rubber seals on the firewall that are going bad. There are likely other things that are easier to get to while the motor is out.
wpavlis is offline   Reply With Quote
Old 03-12-2019, 10:09 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
You can, but Grade 8 is complete overkill for head bolts, and actually in most applications. If you can get them cheaper than the stock head bolts or ARP studs, go ahead and buy them. The head bolts in these vehicles are not tightened to a specific torque plus some amount of turn- they are NOT stretch bolts, and can be reused many times, in my experience.
~Steven
Simi Valley, CA
Old 03-12-2019, 10:12 PM   #11
KevinR
Thanks! This is a great community. I’m learning a lot along the way (younger ish guy here)!
Old 03-12-2019, 10:37 PM   #12
Greasey Harley
Greasey Harley's Avatar
...in addition to what has been listed;
Hoses (all)
belt(s)
motor mounts
battery cables
plugs, wires, cap, rotor (points & condenser if applicable)
fuel filter
oil filter
since you're in there: You might look at the timing chain ...Or are those gears?
Oh yeah, That little rubber grommet that goes around the clutch fork, in the bell housing
I always have a problem with how far to go, and where to stop on these kind of projects.
Good luck, it sounds like a worthy endeavor.
Greasey Harley is offline   Reply With Quote
Old 03-12-2019, 10:47 PM   #13
KevinR
You and me both. It’s always just one more liiiiitttle step
Old 03-13-2019, 01:34 PM   #14
GRX
GRX's Avatar
^^Good mention. They are in fact helical gears. Larger one at the cam is composite to help reduce vibrations and noise. Replacement is up to you OP. May be a bit beyond how far you want to go at this point. Requires removing side covers, lifters, pushrods, etc.
Did all that with my 250 about 10 years ago when I upgraded to the "marine" cam for a bit more performance. Pretty common back in the day.
Old 03-12-2019, 10:11 PM   #15
saxart
saxart's Avatar
I'm going to ask the obvious question here. Have you done a compression test on this engine yet? Would be a shame to put all of this time and money into a dud of an engine.
Old 03-12-2019, 10:50 PM   #16
KevinR
No compression test. My feelings are that outside of the labor and gaskets most parts would interchange if the block ended up bad. I would write it off as a learning experience. I’d like to stick with a 250. I’d been driving it for a year as is with no real issues. This all started with replacing a clutch, and led to a little scope creep.
Old 03-13-2019, 04:50 PM   #17
palallin
Speaking of brakes (if you didn't do this): fresh front brake lines. Much easier to do from the top than the bottom.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-13-2019, 05:07 PM   #18
KevinR
Done with the disk swap! And you’re right, would have been much easier from the top!
Old 03-13-2019, 11:03 PM   #19
Richard Jensen
If you keep it outside in the winter, I'd say add a block heater. My 350 starts and behaves a lot better on those cold mornings. I've been thinking about a heat pad for the bottom of the 700R4 too.
Lead, follow, or get out of the way!
Richard Jensen is offline   Reply With Quote
Old 03-13-2019, 11:15 PM   #20
CastIron
CastIron's Avatar
One thing I did when I had my engine out was touch up the paint on the frame, crossmember, and flywheel cover with some Rustoleum. I also washed and waxed the firewall behind the engine, changed over the wiring to run an HEI distibutor (got rid of the resistor wire), and ran a new wire for the electric choke.
CastIron is offline   Reply With Quote
Old 03-14-2019, 02:50 PM   #21
KevinR
Were all these 250s stock with a composite timing gear? Has mine been replaced?
Old 03-14-2019, 03:34 PM   #22
'68OrangeSunshine
'68OrangeSunshine's Avatar
Depends on the age of the block. I don't know when the nylon gears came in. Possibly, it came OEM, or a rebuilder/PO upgraded to an aluminum gear.
If it's metal, you're good to go.
Old 03-14-2019, 10:19 PM   #23
saxart
saxart's Avatar
Keep us posted on this. I'm curious to hear how it goes for you. Oh, and good luck!
Old 03-14-2019, 10:41 PM   #24
KevinR
Parts started to show up today. Splurged a bit and got new carpet and Trique latches too...nice weather makes me want to get in the garage
Old 03-17-2019, 11:05 PM   #25
KevinR
Quick coat after cleaning half. Other side tomorrow
