Old 03-11-2019, 01:39 PM   #1
Jcfcamaro
Jcfcamaro's Avatar
1972 k10 cab question
Will a low hump cab work with a 700r4 transmission on my 72 4x4? I know from the factory they had the high hump but I'm not walking to cut the low hump out . My plan is to just put the high hump over the top and just cut what I have to for the shifter and probably use 2 boots. But who knows I might just cut the whole thing out.
Jcfcamaro is offline   Reply With Quote
Old 03-11-2019, 08:27 PM   #2
72 tigger
72 tigger's Avatar
Re: 1972 k10 cab question
I think it would be pretty tight?? I would install the high hump
72 tigger is offline   Reply With Quote
Old 03-13-2019, 03:06 PM   #3
Jcfcamaro
Jcfcamaro's Avatar
Ttt. Does anyone have any pictures of the floor where the high hump bolts on. Wondering if its reinforced.
Old 03-13-2019, 10:18 PM   #4
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
It's not hard to replace the low hump with a high hump. There is no need to cut anything. They just bolt in place. Just unbolt the low hump, clean up the surface, and install a high hump. Here is a picture of my K10 4WD with the high hump removed. I have a couple of high humps that I'll probably be selling in the near future. Hope this helps.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-13-2019, 11:11 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
The low hump is part of the floor, it’s not removable. It has to be cut out so the high hump can be bolted in.
Jcfcamaro yes the factory high hump floors have a reinforcement that welds to the bottom of the floor with spot welded nuts for the screws that hold the hump down.
Tyler
Old 03-13-2019, 11:15 PM   #6
davischevy
davischevy's Avatar
It's been a while, but I don't remember cutting the low hump out being a big deal. I think the cut lines are there. I don't think there are any special reinforcements. The factory nuts are welded to the bottom of the floor.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-14-2019, 07:44 PM   #7
derotoreut
derotoreut's Avatar
My mistake. You're correct. I misspoke when I said that. I forgot you have to cut the low hump out. I don't know what I was thinking, because I did so on my 71 SWB C10. It wasn't too hard to do.
My 71 swb with carpet still in place.
Carpet removed
Low hump cut out
~ Dan
Old 03-15-2019, 02:07 PM   #8
Jcfcamaro
Jcfcamaro's Avatar
Thanks Guys for the info and pictures.
Old 03-15-2019, 05:30 PM   #9
Jcfcamaro
Jcfcamaro's Avatar
Hey, could someone that has a factory cab with a high hump measure the hole opening and or the bolt holes on the rear of it to the bottom of the raised brace on the floor.
Old 03-14-2019, 12:00 AM   #10
57taskforce
All about them K’s
This thread may help you see what a factory high hump floor looks like. Davis is correct the cut lines are already in the low hump floor.
http://67-72chevytrucks.com/vboard/s...d.php?t=779161
Tyler
Old 03-16-2019, 10:56 AM   #11
57taskforce
All about them K’s
I can but I won’t be back to my truck until Monday.
Tyler
Old 03-16-2019, 11:06 AM   #12
CharlieBrown
CharlieBrown's Avatar
I did this on my 72...3/4 4x4 auto frame and running gear and a 2wd low hump cab.
you can cut the area out and use the high hump plate with self tapping metal bolts and it works fine.
1972 Cheyenne Super..owned since 1978
1972 Surburban 4x4
1972 Cheyenne 4x4 3/4 ton.....sold
1972 Cheyenne 2wd...named Death Row
CharlieBrown is offline   Reply With Quote
Old 03-16-2019, 11:27 AM   #13
Jcfcamaro
Jcfcamaro's Avatar
My main problem is the cab is sitting on a roller stand and not on my frame so I can't center up the transfer case shifter with the hole on the high hump. I know side to side is good but the front to back is what I'm worried about.
Old 03-16-2019, 11:35 AM   #14
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Your transmission and transfer case will clear your low hump floor with no problems. You only need the high hump on 4 speeds. Plenty of clearance for trans and shifter with the automatic.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-16-2019, 03:40 PM   #15
Jcfcamaro
Jcfcamaro's Avatar
Ok, I have measured and have pictures of the cut out. Went out to a friend's house where he had a 4x4 cab sitting. Now to decide to cut the low hump out or just leave it and bolt the high hump ontop.
