Old 03-14-2019, 08:32 PM   #1
68bbc/20
compressed air question
i'm getting ready to run air about 80 feet to an addition I built on my pole barn
what size, what kind of lines have any of you plumbed your shops with? any special features you did for future use or equipment that might be helpful to
set it up for now while i'm running it? thanks for any input you can recommend. Les
68bbc/20 is offline   Reply With Quote
Old 03-14-2019, 08:39 PM   #2
jcwren
Re: compressed air question
Do NOT use PVC. That's a fragmentation bomb waiting to go off.
1970 C10 LWB Stepside
1971 Dodge Dart
1993 Buick Roadmaster Estate Wagon
jcwren is offline   Reply With Quote
Old 03-14-2019, 08:44 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
It all depends on what you intend to use the "air supply" for?
Most economical is 1" galv pipe...but if the end use is as a spray booth supply...save yourself a huge headache and put another compressor out there....
When plumbing air lines you MUST include drop points with drain valves in each vertical drop line....below the outlet nipple....
Dryers are nice...keeps moisture out of your air tools...(and paint!)....
In long runs, I try and install a ballast tank to provide more air supply load balancing...an old compressor tank works well....
Hope this helps...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 03-14-2019, 08:47 PM   #4
jcwren
<chop>
And cut-off ball valves at logical places.
1971 Dodge Dart
Old 03-14-2019, 08:50 PM   #5
68bbc/20
both are good replies.
Old 03-14-2019, 09:17 PM   #6
B. W.
B. W.'s Avatar
With a run that long I'd go with at least 2" pipe. With a smaller diameter you may run out of air even though the compressor & tank are large enough to supply it.
The great thing about a long run is that your air will be dry. Run it slightly uphill & put a drain at the low end.
And the guys are right about not using PVC but if you are burying the pipe I'd have no issue with it. I have about a 40' run of 2" PVC buried at my shop & have had no issues. If it were to blow no one is in danger. ( been under ground for about 15 years now)
The extra tank that Aussie recommends is a great idea also.
B. W. is offline   Reply With Quote
Old 03-15-2019, 12:19 AM   #7
franken
The issue w/ PVC is it gets brittle when exposed to UV or sunlight or whatever. No bueno for compressed air.
Run air down and no drain at the lowest point and you'll have bad air forever. That means if you want to bury the lines bad things will happen.
People say galvanized pipe flakes the zinc off and blows it through the system so use black pipe. People say black pipe rusts so don't use it. I say design a system where water can't collect.
My theory is water should be caught in the tank (always collects here), in a dryer (might be a simple filter/dryer) or pushed out at the end. Cruel, but the air system purging itself mostly automagically is the important/best part. People pushing multiple drops in a 2 car garage or multiple ball valves are delirious.
My system is log horizontal runs and short vertical runs with unions. It's modular so you can take it apart.. Then at the end, I have a short horizontal run w/ a union where the filter dryer regulator and outlets live. All simple stupid modular expandable shrinkable and made with crap from the home store.
Don't believe me; read up on small shop air systems. Then again, the internet is full of crap.
Old 03-15-2019, 08:43 AM   #8
jcwren
What people really say is use copper pipe. But who can afford that, these days?
1971 Dodge Dart
Old 03-15-2019, 08:24 PM   #9
franken
The typical answer is use black pipe, but then people whine about it rusting--in 50 years. Design and build a system where water has to flush out and your grandchildren could be using the system at the end of the century.
Old 03-15-2019, 12:13 PM   #10
Daaaanz67
My friends auto shop uses PEX. 3/4” on the main runs with 1/2” drops. Seems to be working well for him.
Daaaanz67 is offline   Reply With Quote
Old 03-15-2019, 01:54 PM   #11
Coley
Coley's Avatar
Ok, a couple of important questions to get some needed information:
1) What is the max. pressure that you want to produce? or will be available from your compressor?
2) Are you burying this air line or will it be on the ground or overhead or in a building? (heated or?)
3) Is this 80ft a straight run outside?...or is it 80ft equivalency of a variety up bends, height changes etc as it weaves through and to your new addition?
....lets start there and we can help sort this out.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 03-15-2019, 07:39 PM   #12
68bbc/20
it will be inside a pole barn up and dropped down the walls and thru the trusses 40 feet to reach my addition. building is not heated. I just want air for tools at this time, may consider painting later on down the road.
Old 03-15-2019, 07:41 PM   #13
68bbc/20
tank kicks off at 130lbs.
Old 03-15-2019, 08:04 PM   #14
AussieinNC
Moderator
AussieinNC's Avatar
PEX is not stable when exposed to light...it will degrade....its meant to be used indoors or in crawlspaces or walls...
Black pipe or gal pipe....just keep it running slightly down hill to a drain port and drain all lines once a month in Summer....once every two months in Winter....
2012 Chevy Equinox
