Old 03-14-2019, 08:39 PM   #1
Jeff1971
Ever see inside a double wall top?
I’m splitting mine open in order to do a repair and restore. It took a lot of time but I have half of the outer shell off. I’ll try to update this as I progress.
Jeff
Jeff1971 is offline   Reply With Quote
Old 03-15-2019, 08:30 AM   #2
mister.freeze
mister.freeze's Avatar
Re: Ever see inside a double wall top?
Very curious indeed!
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 03-15-2019, 11:31 AM   #3
lks dcvn
lks dcvn's Avatar
Nope - keep the pics coming though!
lks dcvn is offline   Reply With Quote
Old 03-15-2019, 02:55 PM   #4
Thealien
Thealien's Avatar
I am interested also. I am in the market for a mint 2 wheel drive and want to put on a soft top without drilling the windshield frame. I have an old top from my last Jimmy I could cut up and use that as an attachment point, maybe?
Old 03-15-2019, 10:18 PM   #5
Jeff1971
The front edge of the top is a hollow shell and would need to be reinforced to hold the soft top. When i get back to it I'll show you a picture.
Jeff
Old 03-15-2019, 10:26 PM   #6
Jeff1971
This is the front edge.
Pretty thin . You may use it as a pattern or reinforce it?
Jeff
Old 03-17-2019, 09:41 AM   #7
1972 Jimmy
1972 Jimmy's Avatar
Awsome pics! Got a couple questions for you. Were you able to remove the whole outer shell in one piece? if so how did you separate it around the windows? Also can you take a couple of pictures of the inner channel where the top mounts to the bedsides. curious on how the nuts are fastened to the inner channel.
Thanks eric
1972 Jimmy is offline   Reply With Quote
Old 03-17-2019, 12:57 PM   #8
Jeff1971
Thanks eric
The outer shell has to come off one side at a time. There is a center fiberglass channel that provides much of the support front to rear. This is why when a sunroof is added a lot of the strength is lost. I only have one side off so far. I’m going to develop my methods on the first half first then adapt what works to the second half. As far as separating the seam around the window, I just used a sharp and stiff putty knife and a rubber mallet to slowly open the seam.
Here is the mounting block inside the frame below the window.
It’s just riveted to the lower frame by 2 aluminum rivets. I’m going to remove mine and clean them all up. It’s really easy to just rivet them back on once they are done.
It would be very cool to replace all of those individual blocks with one continuous strip. It would work on all of the except the one in the very back. It’s integrated into the rear metal support frame that surrounds the hatch opening.
Jeff
Old 03-15-2019, 10:05 PM   #9
tristan
(Jeff Spicoli voice) Gnarly!
tristan is offline   Reply With Quote
Old 03-20-2019, 08:48 PM   #10
A1971Blazer
A1971Blazer's Avatar
Do you plan on adding in some extra bracing when you reassemble it?
I thought about doing something similar but short of splitting the entire top....
perhaps just cut off the top section(s) and reinforce with extra braces in the sagging areas
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-20-2019, 09:15 PM   #11
Jeff1971
My thought was to use sheet foam insulation inside. The rigid pink stuff.
Jeff
Old 03-21-2019, 07:19 AM   #12
A1971Blazer
Jeff
I was thinking along the same line. I've been researching and experimenting with different types of epoxy adhesives and also various types of structural foam,
trying to figure out the best way to make a long lasting repair.
I've spoken with the people at FibreGlast.com on a couple of occasions. They offered some good insight on the materials they sell.
My ultimate goal would be to build a complete top out of carbon fiber but I just can't justify the time and expense to do it.
It looks like you're on the right track and I commend you for tackling the job and sharing your experience....
best of luck with it and keep those updates coming !
1967 C10 Step side
1968 C10 Step side
double wall, top
