![]() Join Date: Nov 2018
Brake issues
My front brakes were locking. So I pulled it into garage. Pulled wheels and took it all apart. Rotors were too thin to turn. So I ordered new rotors, calipers and bearings. All came and I began rebuilding. Rotors fine. Bearings fine. Put on calipers. And hooked up brake lines. Passenger side hooked up. Drivers side had wrong brake line connection. Took caliper back to O'Reilly and they had no answer. They say they could re order, but 50/50 chance it would be wrong. They are all same part number. Putting pictures up to show what I have.
The first is connection I have, the second is drivers side as sent. Can i change brake hose? Do i order a new caliper? |
Re: Brake issues
I have a '70 c10 with 71' disc brakes 6-5 lug conversion to front disc.
I went through and changed everything out last year. Stainless lines. Rotors etc. my passenger side has an adaptor fitting on it. I had to reuse that. I'm not sure what size that fitting is but needs to be flared adaptor. Hope this helps. Mark Try this link. Just search it. Not sure if it's what you need https://www.cjponyparts.com/classic-...-1987/p/45045/
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
Re: Brake issues
This is what I got to solve the issue.
https://www.bobschevytrucks.com/1971...hose-left.html I am a bit upset that my left and right will have different hoses. I will have to change again sometime in the future. But this will get my truck back on the road. I can continue to work on other issues for now. Jerry |
#4 | |
Re: Brake issues
The hose was about .125" shorter than the original so at full droop the hoses are really tight. Not a big deal since I will not be off roading the truck and will never see full droop unless it is on a lift or jacked up. I also plan on lowering it and if the drop spindles don't lower it enough I will be taking about one coil length from the springs which will reduce the travel about .5". Just be sure the bleed nipple is on the top of the caliper. |
#5 | |
![]() Join Date: Feb 2016
Re: Brake issues
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 03-16-2019 at 04:15 PM. Reason: -2 grammar |
#6 | |
Re: Brake issues
Nope, the front hoses are about 1/8" shorter then the original front hoses. I replaced all three flex lines because they were rotted from the inside causing not enough brake pressure. The PO who sold it to my buddy had replaced the MC and Booster thinking that was the problem. Oh and BTW, the rear hose all that NAPA offered was either the 18.125" or the 21.125" but not the 13.875" that came with the truck so I will simply install a line clamp to the underside of the bed to take up the slack. I also removed the bleeders and two were rusted inside so they would not bleed correctly so I replaced them with Russel Speed Bleeders. Bob |
