Old 03-18-2019, 05:03 PM   #1
forestb
forestb's Avatar
another tail light question
So a couple of months ago the lights on my gauges stopped working. Then a little while later they started working and then stopped again. Also my front running lights don't stay on but they do work as blinkers. Now here comes the tail lights. The rear blinkers work. The break lights work but the tail lights don't stay on when the headlights are on. I only realized last night that the tail lights were not working. But I am kind of thinking they they are all related sense they should all turn on at the same time. To make things a little confusing it is an aftermarket wiring harness. I have checked my gauge fuse but have not gotten a chance to check my tail light fuse.
forestb is offline   Reply With Quote
Old 03-18-2019, 07:42 PM   #2
Clyde65
Clyde65's Avatar
Re: another tail light question
Get a wiring diagram and start tracing!
I bet yours is like almost everyone’s truck, rats nest and PO cut stuff up.
Good luck!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2019, 11:03 PM   #3
forestb
forestb's Avatar
It’s actually a new harness that was installed in the last 2 years.
Old 03-19-2019, 06:38 AM   #4
PGSigns
PGSigns's Avatar
Check your grounds. I went through the tail light issue a couple of years ago. What U did was put a ground wire from the bed to the frame and added ground wires from the tail light housing to the bed. Made a world of improvement in the way they worked. On the hood I added a ground from the back of the hood to the body. I get ground straps from newer vehicles at the junk yard and use them for a factory look. Now on you front lights if it is a stock harness the marker lights only work in the first position on the switch and go out when the head lights are on. There is a fix to keep them on when the head lights are on and I did that to mine. Requires a jumper between two wires on te back of the switch. It is covered here on the forum just need to do a search for it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-19-2019, 09:29 AM   #5
MikeN
MikeN's Avatar
Jimmy
THIS ^^^^^^^^^^^^^^
It's almost always the grounds.........
MikeN is offline   Reply With Quote
Old 03-19-2019, 11:36 AM   #6
forestb
forestb's Avatar
I will look at the grounds but I know that the tail lights are vary well grounded. The lights on the hood don't turn on even when the switch is in the half position. I know that the buckets are well grounded to the hood but I don't have a ground from the hood to the cab. They work just fine as blinkers.
Old 04-07-2019, 06:25 PM   #7
forestb
forestb's Avatar
So just to follow up I finally got a chance to take a look at my tail lights and guades. After several frustrating hours of surching my dad recamended that I check all the fuses. Even the ones that don't apply. So I didn't and bingo. My horn fuse was burnt out. I checked my horn which I had recently got working and it was not. I changed the fuse and the tail lights and the horn started working. I have to ask the guy that rewired the truck if he knows what's going on. If he wired the tail lights to the horn fuse or if some wire's got crossed. I did get shocked once when honking my horn once.
Old 04-07-2019, 06:42 PM   #8
Indian113
Indian113's Avatar
You just might have something going on inside your steering column. All of the things that you brought up are controlled inside it.
Indian113 is offline   Reply With Quote
Old 04-08-2019, 11:45 AM   #9
forestb
forestb's Avatar
My tail lights not working when the horn wire fuse is out could have to do with something in my steering column? Are you thinking a crossed wire or something wrong with the turn signal switch. My blinkers and break lights were working fine. If that is any help.
If this is any help I connected the power wire that goes into my headlight switch to the wire that goes to the break lights and the break lights worked before I found the burn fuse.
Old 04-08-2019, 07:11 PM   #10
forestb
forestb's Avatar
I talked to the guy that installed the harness and he said it is common for companies to use another fuse to run the tail lights sense they draw so little power. That there is no other place on the block that is marked for the running lights. He said if the fuse keeps blowing out then I probably have a problem but if that does not happen I should not worry about it.
