66 c60 transmission fluid?
Hey guys i am going to replace fluid on my truck since the brakes are all fixed. what kind of transmission fluid does my transmission take and where do i fill and drain. it has the pto attached to it for my dump bed. i am going to degrease it tmrw and take some pics. thanks.
Re: 66 c60 transmission fluid?
Regular 80W90 GL5 gear oil, will work just fine.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Drain plug should be on the bottom and the fill will be on the side. My pto is mounted on passenger side, I filled on drivers. I took a piece of clear hose, maybe 1/2" and connected it to a funnel. Made adding fluid super easy. Of course you can buy a hand pump.
#4 | |
thank you, mine is a 4 speed, pto is on the driver side, i found the drain plug and fill.
