03-25-2019, 02:41 PM | #1 |
new AAW wire harness does not fit new CPP steering column
the harness coming out of my new CPP steering column ONLY APPEARS to be able to fit with my brand new AAW classic update harness. the general shape is the same, the wire colors match up, but the two black plastic connectors will NOT fit together. WHY? must I trim the edge of one of the black plastic ends away to make a connection?
03-25-2019, 04:15 PM | #2 |
Re: new AAW wire harness does not fit new CPP steering column
Why don't use re-use the original connectors that came with the truck? De-pin them and put the new wires in.
72 C10 lwb fleetside -stock 350/350 combo |
03-25-2019, 08:37 PM | #3 |
I've never done anything like that and I was hoping it would be plug and play. Especially considering it's made for this truck
03-25-2019, 09:21 PM | #4 | |
Old member
Coming down to the beach for the RTTS car show I lost my left brake light but turn signal worked. Sure enough the wire was like the horn came loose but not out. I've reinstalled it 2 times so far. I'm really thinking about de pinning it and add spade connectors.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
