03-26-2019, 08:45 PM | #1 |
64 rear axle bearing
Hello all, 2 questions. on my rear axle bearing it has a washer behind it which repair manual calls it a bearing retainer and says to replace when replacing the bearing, but can't find them anywhere, any advice. Next, one bearing i was able to pull it out with my hand the other had to use bearing puller, anyone got a clue on that. tks for any help.
03-27-2019, 01:07 AM | #2 |
60-66 Nut
Re: 64 rear axle bearing
Are you working on a 12 bolt or a Dana 44?
03-31-2019, 04:19 PM | #3 |
12 bolt
03-31-2019, 08:18 PM | #4 |
Moderator
The 64 12 bolt uses a somewhat special wheel bearing as I remember. The 12 bolt truck bearing that was sent with my rear end "kit" was not correct for that year. I would have to be in Texas to get that info though.
04-05-2019, 11:39 PM | #5 |
Had to drive the new bearings in, not sure what was going on.
04-06-2019, 11:35 PM | #6 |
60-66 Nut
The axle bearings are supposed to be a tight fit into the ends of the axle tubes.
04-07-2019, 09:02 AM | #7 |
yes i know they are suppose to fit tight, but can not figure out why old one was so loose. thanks for all input..BY the way captain i switched my 64 to 700r4 auto and i still run the 6 cyl with 1 barrel do you know where i could find a bracket for the kickdown cable,
04-07-2019, 11:08 PM | #8 | |
60-66 Nut
On a 700R4 it is not a kick down cable. It is the TV cable and if it is not connected and adjusted correctly, you will burn up the trans in a short time. Have you checked with Bowtie Overdrives for the bracket? I'm not sure if anyone makes a bracket and the necessary geometry components for a I6 with a 1Bbl. If BO does not have what you need you will have to fabricate all the components yourself.
04-07-2019, 09:38 AM | #9 |
the 63 and 64 outer rear wheel bearing are different to the other year 12 bolt bearings-they have the press on backing plates and different size bearing
04-07-2019, 10:11 AM | #10 |
Moderator
Maybe 63 and back have press on backing plates? My 64 did not.
04-07-2019, 01:21 PM | #11 |
its 63 and early 64 12bolt axles with 17 spline-the later design with 30spline axles are all the same
