![]() Join Date: Aug 2015
WTB - Lower Radiator Retainer
I am looking for 2 lower radiator retainers. These would be the 3.5" size for the standard/smaller sized radiators.
Here is a picture of an upper for size comparison. Last edited by ohboy321; 04-13-2019 at 02:18 PM. |
![]() Join Date: Nov 2018
Re: WTB - Lower Radiator Retainer
Just went to check one I had. It’s only 3.5” and no cooling options listed on the spid.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#3 | |
-Steve |
Well I may have what you need then. You need the metal or just the rubbers? I thought the metal part was made to the core support
I am looking for 2 of the metal lower retainers for now, and will pick up 4 new cushions later. My lower retainers were not attached to the support when I lifted the radiator out, but with the threaded studs on them I think they are supposed to be attached.
I am adding a picture of an upper to show length needed. |
Bump...
Bump...
ttt....
ttt....
![]() Join Date: May 2003
I'll check what I have when I get y from work.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
Hey Steve,
So far I have only been able to locate 1 bottom piece, the other should be around, just not sure where. I should also have the top pieces, because I had to replace all 4 for the larger ones. I'll let you know if I find them. Gary
#12 | |
-Steve |
![]() Join Date: Sep 2007
I have a pair of lower radiator seat mounts. For the four core radiator if you need them
1967custom |
LMC truck has them for both sizes .
#15 |
So it looks like you are needing the two and three row lower radiator seats. I do have those with the rubbers.. I can do$20 shipped
1967custom |
#16 | |
Thanks to all who responded. Like a lot of things on this truck, I really didn't know what I needed at first, but once I started looking for parts the feedback helped me zero in on what I really needed. I do know that reproductions are available, but I prefer to use "cleaned up" OEM parts when I can. -Steve |
#17 |
pm received bud
1967custom |
