Old 04-10-2019, 01:42 PM   #1
anew4961
BIG BLOCK valve train
if you put a roller cam ,lifters,and roller rocker arms do you use different push rods or stock push rods need a little refresher course thanks
anew4961 is offline   Reply With Quote
Old 04-10-2019, 02:09 PM   #2
geezer#99
geezer#99's Avatar
Re: BIG BLOCK valve train
I know a sb has shorter rods. The lifters are taller. Would assume the same on a bb.
Old 04-10-2019, 03:13 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
You would need shorter pushrods if they are hydraulic roller lifters. Solid roller lifters are usually the same height as flat tappet lifters.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 04-10-2019, 08:29 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
Try and by the entire it from same supplier....
Pushrod lengths vary from manufacturer to manufacturer....
BEWARE.....
Make absolutely sure the lifter sets go in the correct way....I have had several "professional builders" install big block roller lifters oriented the wrong way...really quick death to both lifter and cam....makes a huge metal dust mess...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 04-10-2019, 09:19 PM   #5
Mike C
Mike C's Avatar
BEWARE.....
Best advice you will have all week.
I put the Comp SK kit in my 427. Some report the Comp lifters are not the best, but I guess I'll find out...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
