Can water pump go bad?
I have a 1970 with the 250 inline six. I have an engine running hot. I put a new water pump on two years ago because it was leaking. The truck sat for 3 years and now it runs hot. I put in a new 4-core copper radiator and 160 thermostat today. It still runs hot and pegs the gauge.
Can a water pump not work even though it doesnt leak?
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9 Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Can water pump go bad?
You might have air in the system. I usually start the truck and leave the rad cap on loose, air and water will bubble out as it heats up or until you get the air out of it. First time I did this it did the same thing. I usually use water at first to check the system then when its all good put my coolant in. The best way to fill the system the first time is thru the thermostat housing, then the block and radiator are full and it usually takes care of most of the air.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Those water pumps rarely go bad.
Its gonna get hot the first time you run it with the new t stat. Then the t stat cycles and you top off the coolant.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Okay thanks. I’ll check it out again tomorrow after a few heat cycles.
Also make sure you didn't do something stupid like put the stat in upside down.
![]() Join Date: Jul 2018
If the pump is going bad, it’s usually not the pump but rather the bearing at the front. The symptom of that is a seepage from the weep hole on the bottom near the front of the pump. One of the things I do to help purge the air is park it facing uphill. For me it has helped every time.
1971 Custom/10 - 350/3 speed, Orange/White roof |
All about them Ks
![]() Join Date: Jun 2014
Good to see you back Tony, haven’t seen you on here in a while. We’re you able to get your truck registered?
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's 87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue 10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thanks, the truck is registered and insured finally.
This happened to my water pump on a 250, it wasn't very old. I found a new pump with cast iron impeller, don't remember where it came from, though. Probably one of the chain part stores.
I changed out the water pump again and a new temp sensor and it pegs the temp gauge in two minutes or less. Ran a block tester on it and it is getting exhaust gasses in the coolant, turned the blue fluid yellow instantly. Its a head and/or head gaskets.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9 Ford 1985 Chevy C/10 6.0L 4L80 373 locker Last edited by 65standard; 04-16-2019 at 03:42 PM. |
It might be time to look for a 283 or 327
Stick with the 250.
Just my .02 cents. Although, I do like the idea of a 327... Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
I pulled the head. The running hot issue has grown to the worse case.
![]() Join Date: Oct 2009
It's ALWAYS that time
![]() Sorry to hear of the troubles, but getting hot that fast and the symptoms, definitely something wrong there. The ONLY good news is it's not your water pump. EDIT: OUCH! |
#15 |
All about them Ks
Thats what I thought I saw but I couldnt tell for sure.
#16 |
#17 |
All about them Ks
That sucks about your motor. Looks like it was leaking pretty good looking at the valves. It’s hard to see from the pictures but Is the number 2 piston damaged? Looks like it’s got a gouge in it on the front side. I build slant 6’s for a living but I’ve never played with any GM 6’s. A 327 would be a fun setup. I’m glad you got it legally on the road again.
#18 |
Sorry, but I can't tell anything wrong worse than a blown head gasket from the pics. What's up?
My Chevy Truck Project Build Thread '62 Ranchero - 200 I6, 3-on-the-tree, power nothing. '71 LeSabre - 455 Stage 1, power everything. |
#19 |
Good thing you knew how to progress through the proper diagnostics. Sometimes on here you would have been led to checking timing and carb jetting for this...
#20 |
Plenty of V8s around ! The 250 is one of GMs greatest designs period. Chevrolet built its reputation on the L6. I installed a 292 in place of a 250 once thinking it would be an improvement, big mistake ! 250s Rock....
71 C-20 07 Magnum RT AWD |
#21 |
Im saving the 250 for now. I just want to drive this truck. Maybe swap out to a big block in the winter. Good running 454s are easy to find around here. 327s not so much.
The head checks out good. No cracks or warping. Just going to freshen it up and put it back on.
#22 |
![]() Join Date: Feb 2019
Sorry to see the problem. Wanted to share that I once had an over heating problem. it was fine at low speeds, but when you got up to 50-55 it would start to over heat instantly. I suspected a bad hose collapsing because the water pump was brand new. Turns out the impeller was slipping on the shaft when I got up to high speed. Just in case anyone has this issue. Good luck with the engine.
#23 |
The head and block are cleaned up and ready for the new gaskets.
Yes, the head gaskets was leaking, but I think this was a big cause of my overheating problem. This is the lower hose.
#24 |
It does look like drier lint or wool bits. I’m not sure how it got in there other than I put in a new custom made 4-core radiator. Must have been in there and I didn’t see it?
#25 |
All about them Ks
Maybe an old Mouse nest???
