Old 04-18-2019, 03:52 PM   #1
tinydb84
tinydb84's Avatar
Brake set up
Hello all,
I am trying to piece together my brake system. My hotside is really close to my stock brake booster and I switched to rear disc brakes with a Ford 9''. I did some research and wanted some one to look over my parts list before I pull the trigger.
Here is my current issue. My booster is 11 inches in diameter and is about an 1/8'' away from the manifold.
I am thinking of this dual 8 inch booster.
With the rear disc added most things I found said to go with a 77-82 Corvette master cylinder and a disc/disc proportioning valve.
Let me know if I am headed down the wrong path or if I should be getting something else. This is a budget build so I don't want to go with anything too fancy. Thanks for your time.
David
Instagram: myfabguy
Old 04-18-2019, 08:06 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Brake set up
1/8" is way to close....better question is why is it so close? do you have the engine mounted high?..i don't think ive ever seen one that close.the smaller booster is def what youll have to do ..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-18-2019, 09:37 PM   #3
tinydb84
tinydb84's Avatar
Re: Brake set up
Thanks Greg. Any input on the MC or proportioning valve?
The engine is higher due to the Z as well as the manifolds are flipped as part of the turbo hotside.
David
Instagram: myfabguy
Old 04-18-2019, 10:57 PM   #4
mongocanfly
Re: Brake set up
that xplains that then...I was wondering...
I have no knowledge with the brands you've picked,,,,so no help there
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-19-2019, 09:41 AM   #5
SunSoaked
SunSoaked's Avatar
Re: Brake set up
Hydroboost
SunSoaked is offline   Reply With Quote
Old 04-21-2019, 10:59 AM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Brake set up
Why not use a 9" booster? it would give you enough clearance.
Old 04-21-2019, 09:19 PM   #7
tinydb84
tinydb84's Avatar
Re: Brake set up
Originally Posted by SunSoaked View Post
Hydroboost
I did the research to make the switch but I am more just trying to get it running right now. I might swap it out in the future though.
I was thinking I would get a bit more space since the manifold will get pretty hot. Plus I think a dual 8'' would be more assist than the 9'', correct?
David
Instagram: myfabguy
