Old 04-20-2019, 07:32 PM   #1
19steve53
Spindle ID help
I am trying to ID this spindle that is on my BIL's 62 C10. The tie rod hole was drilled out for a 5/8 rod end but I want to go back to a tapered tierod end to work with the Unisteer rack and pinion kit he bought. I am having a hard time reading the numbers on the spindle but maybe someone will recognize it. The rotors are 1" thick. Thanks for any help.
Steve
19steve53 is offline   Reply With Quote
Old 04-21-2019, 01:09 AM   #2
Captainfab
60-66 Nut
Re: Spindle ID help
I have no way of looking up that casting number but if you have 1" thick rotors, it is likely a ~'79-'87 C10 spindle. I am assuming that the entire front suspension has been changed?
Old 04-21-2019, 01:40 AM   #3
19steve53
Re: Spindle ID help
It is still the factory suspension as it still has greasable bushings. I added some extra pics of the spindle and suspension.
Old 04-21-2019, 11:53 PM   #4
Captainfab
60-66 Nut
Re: Spindle ID help
Since those are used with '60-'62 ball joints they must not be original GM spindles. Even though they say GM right on them, they must be aftermarket. The '60-'62 size ball joints will not fit the '73-'87 spindles correctly.
