Old 04-23-2019, 10:32 PM   #1
juiceboxhero
juiceboxhero's Avatar
81 k10 12 bolt differential rebuild
Hello all,
During my drive home yesterday i heard a slight clicking sound. So i decided to pull the diff cover off and this is what happened. It looks like ill have to have a complete overhaul on the diff. My main question on this is has anyone ever gone from what i assume is a series 2 diff to a 3 or 4 and what issues they had? And also since it being 4x4 the front is a corp 10 bolt, i would have to change out the front set of gears as well.
It seems i have a 41/16 gear set (2.56).
Any advise would be appreciated
juiceboxhero is offline   Reply With Quote
Old 04-23-2019, 10:38 PM   #2
mongocanfly
mongocanfly's Avatar
Re: 81 k10 12 bolt differential rebuild
Be a good time to add in a locker....
the gear you use needs to be based on tire size,final trans gear....and dependent on what rpm you want to cruise at..
2.56 is ungodly high....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-23-2019, 10:49 PM   #3
juiceboxhero
I will hopefully have the funds for that. It originally had a 305, still has a th350 without the lockup torque converter. Its on 31s now. Looking into 3.73 which series 4 then the front will have to be changed.
Old 04-23-2019, 10:59 PM   #4
Matt Man
Matt Man's Avatar
Ouch. Parts are readily available for the 12 bolt rear axle. I would strongly advise rebuilding the axle with a master rebuild kit also I would change the outer rear axle bearings and seals while it is out. Just remember that the 12 bolt truck axle is different than the 12 bolt passenger car model. I added a Detroit locker and 4.10 gears
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 04-23-2019, 11:29 PM   #5
mongocanfly
T350 3rd gear is 1:1...with a 31in tire and 3.73s,,,youd be turning 2628rpm at 65mph...
Here's a rpm calc ....i use the bottom box...
http://www.csgnetwork.com/multirpmcalc.html
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 12:05 AM   #6
juiceboxhero
That is one handy tool thanks Mongocanfly. I've never got into a diff before. Doesnt seem to bad. Anybody use the yukon branded stuff? They seems to be good quality with timken seals.
Old 04-24-2019, 07:03 AM   #7
mongocanfly
im putting in yukon gears and a eaton trutrac this week...using the yukon install kit also
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 09:54 AM   #8
juiceboxhero
Would i be safe with this combo? The front would have to come at a later date in the summer.
Old 04-24-2019, 11:39 AM   #9
sweetk30
sweetk30's Avatar
good parts list there on quality and bang for the buck .
1 key point no one has said tho is your 4 wheel drive being a k10 truck so BOTH axles need the gears to match . you cant mix and match or bad stuff will happen . OPPS you said that your self . you can do one axle now and another later just dont use 4x4 until there matched .
the true track is a solid unit for street and med off road for the 31" size tire .
might be worth your time to look for sale ad's in your area with a pair of take out axles with better gears and go this route but thats up to you .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 04-24-2019, 11:52 AM   #10
mongocanfly
yep ..thats what ive got for my rear...for my front i went with richmond...its a little cheaper and since the front is seldom used itll be ok....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 11:58 AM   #11
juiceboxhero
Thanks Sweetk30.
i would take more time for used parts but being my Daily and i am having to borrow the wife's MDX(she's not to happy). I will be able to look for the front throughout the summer and get it done by winter piece by piece.
I cannot complain about the truck, i traded A 93 c1500 longbed v6 for it.
i was just astonished it had 2.56 gears in it. Even with a slightly aftermarket 350 it was a dog on takeoff.
Old 04-24-2019, 02:26 PM   #12
1976gmc20
2.56 gears
I wonder if that is what I had in my 1980 K-10 that I bought brand new and sold a couple years later?
It had the Sm465 and you had to be almost 35 mph before you could get it in high gear. You could easily run it up to about 60 mph in 3rd gear which was nice for pulling a trailer up a hill.
It did get 18 mpg at 55 mph and 15 mpg at 80 mph (when/where I could get away with it).
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 04-24-2019, 03:07 PM   #13
sweetk30
sweetk30's Avatar
going from 2.56 to 3.73 it will be a ROCKET SHIP
you doing gears ? if so have you done this kind of thing before ?
Old 04-24-2019, 03:14 PM   #14
juiceboxhero
I will be doing them, yes.
I have little experience with these, so instructions will be my friends. I have almost all the tools. Gonna triple check everything before i begin to install anything.
Old 04-24-2019, 03:13 PM   #15
mongocanfly
my 86 had 2.73s in it with a sm465
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 03:17 PM   #16
mongocanfly
if youve never setup gears before it can be quite intimidating for a beginner....ive done several and i still get frustrated...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 03:33 PM   #17
juiceboxhero
Just from watching various videos it seems tedious to get it set in properly. But i gotta learn how to do it anyway.
I was hoping to do it without taking it out from under the truck but i dont think its an option now.
Old 04-24-2019, 11:15 PM   #18
sweetk30
sweetk30's Avatar
i have all the tools and still dont like them . shimmed axles suck for learning . 14ff rears / ford 8" & 9" and others with bolt in sandwich shims and threaded adjuster are the BEST to learn on .
these are not 12 bolt axles but read them to get a good idea .
basics and full shim axle style http://www.pirate4x4.com/tech/billavista/Gear_Setup/
14ff rear 3/4 or 1ton easy to learn on . https://www.pirate4x4.com/tech/billa...4b_Gear_Setup/
dont go asking much on pirate4x4 forum as there real RUFF over there . but the tech is super good most of the time.
Old 04-24-2019, 11:19 PM   #19
sweetk30
sweetk30's Avatar
any 1/2 ton square body axles will bolt under 12 bolt or newer 10 bolt . if you dont care for o.e.m or just need it rolling heck find any good 6 lug rear to bolt in . might need a trick joint for the 12 bolt to 10 bolt u-joint size on the yoke .
also i HATE crush sleeves so i do the solid pinion spacer conversion . little more to setup for well worth it for maintenance later . https://www.summitracing.com/parts/rat-4107/overview/
Old 04-26-2019, 12:38 PM   #20
juiceboxhero
It even came with a "free" hat.
So the plan is just replacing the components and not a donor rear. Been reading a lot on this forum and videos. Got all the tools to complete the job right. Hard to weed out bad advise on some forums.
Pinion depth is my only worry.
Old 04-24-2019, 03:52 PM   #21
mongocanfly
i wouldnt do it in the truck unless you had it up on a lift...it also would help if you has a experienced person guiding you along..even if you pay somebody to do it for you get they might let you "help" ..
like k30 stated...you might be better off searching for a axle from a donor...quicker-cheaper
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 06:00 PM   #22
juiceboxhero
Do you know what years would have a similar differential that is compatible with these 12 bolt?
Old 04-24-2019, 08:48 PM   #23
mongocanfly
If your looking just for a differential then youd need a 12bolt from a truck.....car 12bolt wont work
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 04-24-2019, 10:35 PM   #24
juiceboxhero
Well i pulled this out of my bookshelf. Completely forgot about this gem. Gonna hunt around for the next few days for a inexpensive donor diff.
Ill post updates as soon as i get the build together.
Old 04-26-2019, 01:40 PM   #25
mongocanfly
Dang it!...They didnt send me a hat...only a big invoice...
When you pull yours apart, press the old bearing off your old pinion and start with the shim that's in there...on the back of your new pinion there should be centerline to pinion measurement...that's a starting place...take your old bearings and hone them out so they will slip over the pinion with minimal effort..use these for setup only..not for final use..
Mongo...aka Greg
RIP Dad
RIP Jesse
12bolt, differential, k10
