![]() Join Date: Nov 2018
big block GMC
I have a 71 GMC C3500 longhorn with a 402 in it. The stamp on the block says it is a chevelle engine from 1970. The engine runs fine. But, everything under the truck is leaking and wet. Engine, TH400 transmission and even the rear end.
As of now I am rebuilding the front disk brakes. Had a lot of issues with hoses and the like. When I got the truck I was able to drive it to get tires on it, the old 16.5. So I have a lot to do to the truck to make it my weekend driver. When I got it up to 50 MPH, it was reving really high in my opinion. I have no tach. So maybe this is normal for the TH400. Maybe the transmission is slipping. I have looked at rebuilding the 402. I am getting prices around $2500 to $3500 to rebuild the 402 to stock. I can buy a 454 rebuilt for around $4000 or less. Most of my searches show the 454 as a long block. Is the 402 I have a long block? To put in a 454 in its place will I need to change motor mounts, radiator and things like that or can I pull out 402 and put the 454 right in? I will also need to rebuild this TH400 or get another in better condition. So I am trying to plan ahead on my restoration. There is body work to do. Cab mounts. New wood bed. Enough to be overwhelming. The 402 while having good torch is mild on Hp. I looked up the numbers on the block, and it was rated at 330 hp in 1970. I am sure that is good for the truck. It sounds good, but would not cook tires at all. Maybe the old transmission. I would like more from my dream truck. What does the group have to say? What is on my list of options? Jerry ![]() |
I have a radical idea!
Re: big block GMC
The term “long block” means the rebuilt engine is complete with heads. It has nothing to do with size. “Short block” means block, rotating assembly with pistons only, but no heads.
Your 402 and a 454 is the same size dimensionally and a 454 will right in place of a 402. Both are considered big blocks. Your engine is revving higher than you’re probably used to because the TH400 has no overdrive and the truck probably has pretty low gears. An OD transmission would be the best solution, but you could possibly put higher gears depending what differential you have.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Re: big block GMC
thanks for the clarification on terms.
Who Changed This?
![]() Join Date: Jan 2013
Re: big block GMC
Most 400 CI engines with an automatic came standard with a 3.54 axle. To your ear, it's probably revving pretty high because most vehicles made in the last 40 years have some sort of overdrive and a lockup converter. When I don't pull a trailer, I could use an overdrive on the freeway. My truck has the torque for it, as long as the RPMs are in a decent range not to lug it. But I wouldn't use an overdrive gear when towing. I'm actually going to do nothing with my truck in terms of electronic transmissions, fuel injection and so forth, because it's just expense that while giving better mileage, won't give me a return in my lifetime. BTDT with my Buick hotrod and an overdrive trans.
Re: big block GMC
Something to think about: Find someone-shop in your area that specializes in older vehicles and spend the money to have the truck completely assessed end to end. There’s a good chance there’s absolutely nothing seriously wrong with any part of the drivetrain. A thorough check of the engine transmission etc. can can determine if a rebuild is necessary or simply a reseal And replacement of wear components. You could save yourself a ton of money and labor and have a good bottom line starting point before you proceed.
Steve weim55 Colorado |
#6 | |
Re: big block GMC
#7 | |
Re: big block GMC
However, I agree with having a shop look the whole truck over and see what needs to be done. You may not even have to rebuild anything, just replace gaskets to stop leaks. I will say, my 454 is great at cooking tires. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: big block GMC
454 requires a different a counter balanced flexplate and harmonic balancer.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: big block GMC
Good to know for sure that a big block is a big block. I would not use my intake from my 402. I am told the biggest issue with the 402 is it's airflow. So if I upgrade to a 454, I would make sure to upgrade airflow.
Re: big block GMC
Jerry, nobody here wants you to think less of us for our interest in guiding you in your quest for a complete better pickup build. Sometimes our words may not sound kind, but most here are veterans at working on this stuff. Either making it stock, or hopped up!!!
Whatever intake is on your engine, will likely perform greatly on a 454 also. Your 402 was likely not a huge power maker, even stock. They did run well, even in a 3500!!! Check online for 454 engines. New ones to be exact. If you have a generous buget, that would be the way to go!!! GM Performance parts, Scoggin Dickey (a dealer for GM Perf parts), Summit, and many others. Some pictures of your pickup would be cool!!! |
Re: big block GMC
I am happy to show my truck. She needs so much work. Her name is "large marge" she is a 1971, GMC C3500, 1 ton custom camper. I have original sales receipt.
Re: big block GMC
I have her up on jack stands now. Getting front disk brakes done. I was loving the sound of the 402 but was underwhelmed by its power. I priced rebuilding 402. And thought why not get the best powerhouse in my truck. The 402 in it shows it is a 70 chevelle motor. May be original and may not be. It is my truck now so if I want a meaner motor, why not
Who Changed This?
Re: big block GMC
I don't know what kind of clapped out 402s you guys have, but even with 120k+ miles on my rebuilt engine, it takes off laying rubber and will chirp second, even with that camper shell. I get hole shots from traffic signals on ricers all the time. It's great fun!
Re: big block GMC
Cool truck. Do you have picture of the SPID you can post? (Service Parts Identification label that is affixed to the inside of the glove box lid). Also a picture of the rear axle cover.
As mentioned before, most big block trucks came with the 3.54 geared Dana 60 rear axle, but as a 1 ton it could well have been optioned with lower (higher numerically) gears for towing performance.
#15 |
Re: big block GMC
Nice truck Jerry! I would try tuning your motor a bit to make sure it's running proper before giving up on it! These old things leak, but that doesn't mean they're worn out! If you could get by with some gaskets and tuning that 3k or so could go a long way elsewhere... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#16 |
Re: big block GMC
This is SPID
