Old 04-30-2019, 10:36 AM   #1
bobcat1
kick panel measurements
I am replacing my firewall panel and the prior owner had filled some areas with fiberglass and brazed in patches, (made a mess really) I need a measurement from the a pillar to the top of the flange the firewall welds to. a measurement from a pillar to where the firewall changes from 3o to 40 degree would be most helpful. hope the attached photo helps explain. thanks guys
bobcat1 is offline   Reply With Quote
Old 04-30-2019, 01:47 PM   #2
Mts67C10K20
Mts67C10K20's Avatar
Re: kick panel measurements
A little more context in the pic would help
I am working on my cab also and may be able to help
Mts67C10K20 is offline   Reply With Quote
Old 04-30-2019, 03:50 PM   #3
bobcat1
the photo is with the cab lying on its back and the view is from the passenger side. the "a pillar is at the bottom of the photo horizontal. at the top is the new firewall panel . I am looking for a measurement from the a pillar to the point where the firewall flange breaks over . this is where I have drawn the vertical line. the lines I drew at the top of the photo approximate first slope of the flange and the second slope of the flange. hope this helps clear it up.
Old 04-30-2019, 04:51 PM   #4
Mts67C10K20
I'll try to get to the building tonight for a measurement
If not Thursday for sure
Old 04-30-2019, 05:48 PM   #5
bobcat1
thank you mts
Old 04-30-2019, 09:54 PM   #6
Mts67C10K20
Hope this helps
Use bottom scale ...6 7/8"
