Old 04-30-2019, 03:44 PM   #1
72c20customcamper
72c20customcamper's Avatar
Ho52 wheel bearing torque
I looked up the torque in my shop manual page 690 it says to torque the inner nut to 50-60 ft lbs . Then adjust nut backoff 1/8 to align tang on nut lock . Outer nut to 175 ft lbs. But it says this is for barrel roller bearings . Mine looks to have been replaced with tapered bearings. I can't see going that tight on a tapered bearing. Any advise as to proper torque or do I do it like the fronts . Tighten to drag then back off to lock in.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-30-2019, 07:16 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Ho52 wheel bearing torque
The 10.5” floating 14 bolt uses tapered bearings and you torque them to 50 then back them off and set the lock washer like above. The outer Then gets 100 if I remember right. I don’t think 50-60 is too much personally. If your talking about the outer nut I’d do what the manual says there.
Tyler
Old 04-30-2019, 08:36 PM   #3
72c20customcamper
Thanks guess I'll do it as per the manual
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-30-2019, 08:47 PM   #4
Furno68C20
off the subject but where do you get this so called manual? I'm sure LCM has it or Brothers, any alternatives?
Furno68C20 is offline   Reply With Quote
Old 04-30-2019, 09:09 PM   #5
FirstOwner69
FirstOwner69's Avatar
Chassis Service Manuals here:
http://67-72chevytrucks.com/vboard/s...ghlight=hatzie
Most torque values are listed by manual section at the end of the manuals.
FirstOwner69 is offline   Reply With Quote
