![]() Join Date: May 2013
4wd Power steering question
I am putting power steering on my 67 K10. I already have the Capt Fab bracket, a pump and pulleys. Is the only difference between the 69-76 and 77-79 steering boxes the rag joint shaft diameter? The 69-76 boxes are back ordered till the end of the month. Thanks John
#2 | |
![]() Join Date: Aug 2014
Re: 4wd Power steering question
1972 Chevy Custom Deluxe Highlander, owned 34 years. 1970 GMC Sierra Grande 2500, unrestored, original. 1970 Chevy K10 Short Wide-bed, working on restoration.. 1967 Chevy K10 Short Stepside, unrestored original. 1969 GMC CST (Longhorn) 396, buckets, unrestored. 1995 GMC K2500, 65,000 miles, 454. |
Currently Blazerless
The only difference in the steering boxes that I know of is that around 76 they went from a flare nut fitting on the hoses to an O ring fitting. So check your high pressure fitting on your pump and get the correct steering box to match.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
o-ring hose didnt happen until 1980.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
All about them K’s
![]() Join Date: Jun 2014
Some of the later boxes are a quicker ratio as well. I’ve never run into the rag joints being an issue. Maybe I just got lucky.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
![]() Join Date: Oct 2016
I think the input shaft changed in 77. I ended up going crossover steering (2WD box) but I think I just shopped Rock Auto for a flare fitting box with the faster ratio. It was an earlier 67-76 type box and it took a Lares 201 rag joint. The spline description on their site is messed up and I ordered the wrong one first, then called Lares and talked with a really nice guy who told me to ignore what they say and order a 201.
__________________ '68 K10 496/465/205 |
