Old 05-06-2019, 07:23 PM   #1
USAF
HO52 Rear Disc Brake Conversion Accomplished By Anyone?
Am considering one of the 2 kits at the below links and am wondering if anyone else has performed this upgrade yet. Thanks if anyone can provide your experience/opinion with this.
https://lugnut4x4.com/product/62-72-...onversion-kit/
http://www.ruffstuffspecialties.com/catalog/R2053.html
1972 K20
2004 Chevy Aveo
2011 BMW X5 Diesel
2018 Chevy Silverado Diesel
U.S. Air Force Retired - 1983-2017
USAF is offline   Reply With Quote
Old 05-06-2019, 08:49 PM   #2
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: HO52 Rear Disc Brake Conversion Accomplished By Anyone?
I did a conversion but I pieced it together myself. The hardest part was rigging up brackets for a parking brake cable setup. Details are in my get driveable thread (see link below). Those kits look decent priced.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 05-13-2019, 04:12 PM   #3
5foot16
I did the lugnut 4x4 conversion on my 69 c20. Also an Eaton H052 rear end. Everything bolted together nicely and no problems with fitment for 16" wheels. I am also not running a parking brake. The only thing I needed to make the kit work was longer studs.
Every time I have sent Shawn @ lugnut 4x4 an email, he responded within minutes. I would reccomend him.
5foot16 is offline   Reply With Quote
Old 05-13-2019, 07:44 PM   #4
bris-k20
I did the ruff stuff kit last fall. It was simple and easy to install. You do lose the e-brake, but if you want to spend the money they now sell a caliper that’ll work and has the e-brake, which I may end up adding on later. Only issue you’ll have is you’ll have to drill out the hub to do 9/16” studs. The studs they recommend in the kit worked perfect. I couldn’t find anyone that would drill them for me(I guess liability issue?) so I did it myself. If you do it yourself I used a 19/32” to drill it out and they seated good. The drilling was the only pain part of it. Only other issue I had was the brake line wouldn’t come apart, so I ended up replacing the hard line that runs across the axle to the drivers side.
bris-k20 is offline   Reply With Quote
Old 06-05-2019, 02:54 PM   #5
USAF
5foot16, how did you connect the brake lines since the size is different from the original to the new caliper brake line? The rubber hose I got isn't nearly long enough to reach the junction by the differential. In your pics I see you didn't hook up the lines yet. Thanks.
1972 K20
2004 Chevy Aveo
2011 BMW X5 Diesel
Old 06-06-2019, 04:26 PM   #6
5foot16
USAF,
I cut the hard lines down to the inside of the u-bolts and put new nuts on and flared them. I went to my local Star Auto Parts store and they had brass adapters to connect the hard line to the new stainless hose. I don't remember the sizes off the top of my head, but I hope that helps.
