Old 05-10-2019, 09:05 PM   #1
dondb
WP pulley diffrences?
I'm installing PS and the crank pulley and WP pulley were so close i couldn't install the PS belt. The WP pulley I removed was 7 1/8" across, so I purchased a 6 1/4" across pulley. The bolt pattern was different...1 1/2" between bolts on one I removed and 1 1/4" on one I bought. Needless to say the mechanical 4 blade fan and spacer do not fit on the new pulley. I believe the set up I pulled off was not original to the 307 engine due to the crank pulley being smaller then the WP pulley and the one I purchased to be correct. So my question is what fan and spacer should I buy and were?? Oh yea... the fan is 18"
Thanks for any help and suggestions
1969 C-10 LWB SS
1969 Camaro Pro Tour
2002 Camaro SS LE Rag Top #937
dondb is offline   Reply With Quote
Old 05-10-2019, 10:03 PM   #2
MySons68C20
MySons68C20's Avatar
Re: WP pulley diffrences?
A picture would help alot.....trying to visualize your particular problem is tough without it.
MySons68C20 is online now   Reply With Quote
Old 05-11-2019, 09:43 AM   #3
gmc684x4
I can pull off the fan and pulley of my 91 later today and compare it to my 69 pulley for bolt pattern spacing
I am going to use the 91 serpentine setup on my 72 when I get the motor built and keep the original setup in my 69
I just finished shoving in the 91 into the shop last night to start tear down runs great bent frame got it as a parts truck
Looking forward to driving my 69 this week
I have swapped the clutch style fan into my truck in the past and pulled it out and put in my moms ford when her clutch fan failed and went back to my old 4 blade fan
both the short pumps I have on hand have dual bolt patterns drilled
I always guessed small block chev where almost all the same bolt pattern
gmc684x4 is offline   Reply With Quote
Old 05-11-2019, 12:09 PM   #4
dondb
I'll post a picture a little later when i can get into my shop.
And I think that's what I'm going to do....drill new holes in the pulley to match up the spacer and fan blades? The center part will keep everything centered to drill the holes so there's no wobble??
Thanks for the response Should be a few days longer before i get the truck on the road minus the bed which is getting new wood.
1969 C-10 LWB SS
Old 05-11-2019, 12:17 PM   #5
Myself
On the v-belt smallblock setups there is a short water pump style, then an early long style, and a later long style too.
Myself is offline   Reply With Quote
Old 05-11-2019, 02:11 PM   #6
dondb
1969 C-10 LWB SS
