05-16-2019, 08:16 AM | #1 |
Brake Pedal Push Rod Suggestions
looking for the best option. i installed an 8-inch power booster and need the rod from there to the brake assembly.
05-16-2019, 11:26 AM | #2 |
Re: Brake Pedal Push Rod Suggestions
Most folks just lengthen the stock rod. If you go to the FAQ section under the part on power brakes there are lots of info on how folks have done it. There are also threads on drilling the mounting hole on the pedal 1" lower to improve the ratio.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
05-17-2019, 12:43 AM | #3 |
Here's a couple of possibility's
https://www.speedwaymotors.com/Unive...Long,9330.html https://www.speedwaymotors.com/Wilwo...it,136383.html https://www.speedwaymotors.com/Speed...od,296871.html https://www.speedwaymotors.com/Forge...-Rod,1539.html https://www.speedwaymotors.com/Unive...Heim,9329.html |
05-17-2019, 12:52 AM | #4 |
But Found Her 25yrs Later!
I did this...
05-22-2019, 11:05 AM | #5 |
hmmmm, I missed this step. 1" lower? What kind of difference does it make? If you push the MC all the way is it just for a better pedal feel?
05-17-2019, 09:09 AM | #6 |
I just recently replaced the MC/booster assembly on my brother's '65. I made sure to order a unit that had the adjustable rod included and relocated the hole like other's have mentioned. On a couple of others, the existing rod was modified.
05-22-2019, 01:06 PM | #7 |
Moderator
It usually fixes a pedal ratio problem - read this: https://techtalk.mpbrakes.com/brake-...rd-brake-pedal
and/or this: https://techtalk.mpbrakes.com/how-to...ng-pedal-ratio
05-23-2019, 09:36 PM | #8 | |
