05-18-2019, 10:47 AM | #1 |
New "66 fleet side - what manual tranny should I go with
I have a 1966 fleet side I'm getting in couple weeks. I have a 1969 fleet I rebuilt from ground up with 5.3 LS and 4L60E and now due to divorce I'm getting a 1966 fleet that I'm going to start from ground up also. But, it's getting a 383 full roller stroker that is sitting on floor, Fitech blow thru fuel injection, and I want to go with a manual tranny. My concern is what manual should I get? Looking for good fit, not super expensive, but maybe a range of ok, good to great. Any help is greatly appreciated.
Thank you for your time to respond |
05-18-2019, 01:38 PM | #2 |
Re: New "66 fleet side - what manual tranny should I go with
NV3500 came behind the 5.3, didn't it? Likely won't take boost, but common and cheap.
World-Class T5. If you're nice to it, almost any trans will do fine.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-18-2019, 03:36 PM | #3 |
That 383 will eat that nv3500 in a New York minute.
Your gone need a Tremec or a nv4500 for that beast
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-18-2019, 04:36 PM | #4 |
To Skinny's point - a T5 will last just fine behind a 900hp big block - DEPENDING on how it's driven. Generally speaking though, if you're building a stouter motor, there is a reason - so T5s and NV3500s aren't perhaps the best choice behind anything but a small V8 or behind something you KNOW you won't be doing burnouts in or towing/hauling with.
05-18-2019, 07:42 PM | #5 |
Your rear end gears and tire size will have some bearing on your choice. My truck is currently receiving a Muncie M22Z swap with a 3.08 rear. I personally wanted to keep it old school but still wanted a decent highway cruise rpm. The M22Z has a 2.98 first so it should provide a decent launch and the even gear spacing should provide nice rythmic shifting. It also will easily fit my low hump floor and I can keep my cast iron bell housing along with the stock clutch fork and linkage. Lots more to read if you Google it. Edit: Also, I recommend using the various ratio calculators available online to determine the final drive rpm and mph, shift points, and starting line (or launch) ratio for your given set up.
05-18-2019, 09:48 PM | #6 |
I really wanted a stick in mine, but I couldn't afford a strong enough stick to live behind a boosted 6.0L, so I went 4L80. A tremec, while nice, is a whole lot of change unless you are really lucky/resourceful. An NV4500 would take ALL the abuse, but I didn't want a "truck" trans in mine.
05-18-2019, 10:09 PM | #7 |
I am putting a Tremec T56 Magnum in mine. I wanted a stick as most of my vehicles have been sticks...I should be installing it in the next few weeks.
05-19-2019, 12:12 AM | #8 |
60-66 Nut
The way I see it you have 2 choices with that engine. A TKO-600 or a T56 Magnum.
05-19-2019, 10:48 AM | #9 |
Moderator
T56 with 4.10s will work wonderfully with that engine. It will pull like a freight train 1-4, have 5th for in town OD, and deep 6th OD for the highway. My car with a swapped T56 and 4.10s turns barely over 2000 at 65mph. Even a WC T5 is not strong enough for that stroker.
05-19-2019, 11:05 AM | #10 |
Just mounted my T56 Magnum to my SBC with FiTech EFI today...good looking trans! I ordered the mid shifter, but it is on backorder...so the shifter is too far back for a bench seat.
05-29-2019, 12:50 AM | #11 |
I thought I wanted to go with a Tremec TKO 600 in my 62 C10 until I figured out after spending over $2600 for the tranny I still have to buy a mid position shifter for several hundred dollars more so I can even use it in my truck.
Should be an option of shifter position after spending that kinda money! |
05-29-2019, 06:42 PM | #12 | |
05-29-2019, 09:37 PM | #13 | |
05-29-2019, 10:47 AM | #14 |
I was wanting the TKO for me as well, but then an LS/4L80 fell into my lap for less than a third the price of a TKO swap. Going slushbox now.
05-29-2019, 05:46 PM | #15 | |
I already bought a brand new crate 350 I'm putting in place of tired 283, truck already had a World Class Camaro T-5 with S-10 tailhousing that I'm re-installing, but it kinda whines a bit...only a matter of time till it goes bye bye I think? |
06-06-2019, 04:46 PM | #16 |
Goodness, I was really hoping to go manual but after reading all the comments..... I really want to go old school and throw a good Muncie in it though. I am still thinking on this. I need to decide what way to go as I start the tear down within the next few weeks and want to have a solid game plan.
