NV4500 swap 1987
Has anyone done a SM465 to a NV4500 swap recently ? I am currently doing this on my 1987 K30. Most of it is going well and the trans. mount and drive lines fit perfect. I had a question on the studs that A.A. supplied with the spacer. I believe I read somewhere that they were too long. Anyone have any info ? Thank you
Bill @ Vintage Chevy Trucks |
![]() ![]() Join Date: May 2015
Re: NV4500 swap 1987
are you referring to the transfer case adapter?
Yes I am. I have the spacer that is about 1 3/4 to 2" thick. They included all thread studs. After I posted this, I took a small pick and checked all 6 holes. 5 of them have a bottom, one goes into the case. I'll have to be careful not to let it screw in to deep and I will match the others. Now the problem is the spacer is not an easy fit on to the front of my 205. I am sanding it smooth right now.
i used red thread locker on the all thread / studs to help hold them in the case .
as much as they get for there crap you would think we would be getting real studs by now . even with the spacer you need to cut a chunk out of the nv4500 adapter to clear the shift rail and linkage . pic looking down at the case from up in the cab .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
I put the spacer on and I'm thinking that they really need to do some more engineering on it. I will have a friend that owns a machine shop around the corner, clean this up for me before installing. I have already cut and trimmed the end of my NV4500 where it meets this adapter. I also extended the Transfer case lever bracket and made a L shape on the end. It fits perfectly with bolt hole at about 2:00 position.
What year 205 do you have. The newer style (86-87) take a different spacer /ring. Mine has the 6 bolt, round front.
