Idler/Pitman Arm Torque
Does Anyone Have The Torque Value For The Pitman and Idler Arm To The Cross Shaft Where The Tie Rodends Bolt To? Thanks
Posted via Mobile Device |
![]() Join Date: Mar 2003
Re: Idler/Pitman Arm Torque
tight, then lineup the cotter pin hole
From 1970 service manual:
pitman arm to relay rod nut and idler arm to relay rod nut are both 60 ft/lb
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
Thanks Guys. I Also Have 2 fosm Washers. 1 is 1/4 inch and 1 is 1/2 inch. Where do these go. Somewhere on the idler arm or pitman arm?
Pretty sure there is one between the pitman arm and the cross shaft. I assume the idler arm is the same way.
