Old 11-29-2003, 12:11 AM   #1
valley 67
valley 67's Avatar
fuel cell pics
1
valley 67 is offline   Reply With Quote
Old 11-29-2003, 12:14 AM   #2
valley 67
valley 67's Avatar
2
Old 11-29-2003, 12:15 AM   #3
valley 67
valley 67's Avatar
3
Old 11-29-2003, 12:16 AM   #4
valley 67
valley 67's Avatar
4
Old 11-29-2003, 12:40 AM   #5
jamis
F.A.S.T. president
jamis's Avatar
sweetttttt
jamis is offline   Reply With Quote
Old 11-29-2003, 01:25 AM   #6
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
Well...
looks like it fit. Did I not provide enough clearance for the sending unit and the front crossmember?? Hard to tell in the picture. Looks good and thanks again. FCG
FuelCellGuy is offline   Reply With Quote
Old 11-29-2003, 11:00 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Man that is a nice looking fuelcell mark look's like you do good work.. Valley that is a seet a$$ truck can not wait to see it done..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-29-2003, 01:33 PM   #8
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
very nice......
67Fleetsidedream is offline   Reply With Quote
Old 11-29-2003, 02:10 PM   #9
miket
miket's Avatar
Looks nice...boy you know I really need to look at doing that. The only part that concerns me is the filler. Whats everyone doing for a filler?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 11-29-2003, 02:10 PM   #10
72superBB
72superBB's Avatar
So what does a setup like that run? I want to do that tp my truck. Looks great.
Life is full of choices and a Chevy is the best choice.
1990 Chevy SWB
72superBB is offline   Reply With Quote
Old 11-29-2003, 09:59 PM   #11
Stroker
Nice!!! How much fuel will it hold, 16gal?
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 08-17-2004, 10:24 PM   #12
flatblackclassic
HOw much fuel will it hold?!!! It looks like it affords quite a bit more clearence than the blazer tank which is what I'm looking for since I'll be going bagged eventually.
flatblackclassic is offline   Reply With Quote
Old 08-17-2004, 10:31 PM   #13
FuelCellGuy
FUEL CELL GURU
I believe his was about 19 gallons according to the dimensions. You can barely see my 16 gallon tank peeking out from under my truck in the following pic. Later, FCG
Old 08-18-2004, 01:03 AM   #14
70-Chevy
-Chris
70-Chevy's Avatar
how much does one of those things cost?
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 11-29-2003, 10:44 PM   #15
valley 67
valley 67's Avatar
PRICE IS GREAT IMO TALK TO MARK HOLDS 19+ GALS FILLER IM USING IS COOL CAP THAT WILL BE ON BED FLOOR. AS FAR AS CLEARENCE ITLL BE OKAY FRONT BAR BOWED A LITTLE SO SENDER SCREW WILL CLEAR
Old 11-30-2003, 12:09 AM   #16
K5KRAZIE
That is the ticket, almost a shame the bed has to go over it .......
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
Old 11-30-2003, 01:01 AM   #17
Piper71c10
Unending Project
Piper71c10's Avatar
Looks great. You are way ahead of me on the install. <twitch>
All I wanna do is go work on the truck...
Piper!
Piper71c10 is offline   Reply With Quote
Old 01-10-2004, 12:18 AM   #18
DSW
I did not want a cell thanks thought
Looking for 67-68 short step side body thats in great shape and suburban body thats in great shape and both have to be in tx Dfw
DSW is offline   Reply With Quote
Old 08-18-2004, 01:14 AM   #19
67cst
i love summertime
67cst's Avatar
do you tig those tanks or do do you use a spool gun with aluminum wire?
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-18-2004, 07:38 AM   #20
FuelCellGuy
FUEL CELL GURU
450HP,
The tank kits are $375 + shipping for the version used with a carb. Kit includes tank, straps, sending unit, upper crossmembers, filler tube or flush mount filler assembly.
67cst,
100% TIG. They are MIG welded on the inside seams before the topp is put on.
Later, FCG
Old 08-18-2004, 08:00 AM   #21
bigblock73
yeller
bigblock73's Avatar
Mark, you do excellent work! I wish I knew of you before I spent the money and put in my 16 gallon Summit cell. I still like my setup, but the extra capacity would have been nice.
Valley 67...trucks looks exceptional...wow!
bigblock73 is offline   Reply With Quote
Old 08-18-2004, 08:09 AM   #22
Bowtiefreak
Bowtiefreak's Avatar
fuelcellguy's stuff
is top notch. I purchashed a tank and his polished armrests. Great stuff
1968 Chevy C10 Short Fleetside/Wood floor
ECE 4-6 Drop / 406 Small Block
1971 Chevelle 427 Big Block
Bowtiefreak is offline   Reply With Quote
Old 08-19-2004, 09:45 PM   #23
nate68
what are the dimensions? i need something like that when i go to efi
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 08-19-2004, 09:55 PM   #24
Bowtiefreak
He will make them to whatever size you want and put fittings in any place you want also.
Old 08-20-2004, 12:34 AM   #25
nate68
i have someone here that could do it for me. although that is a very good price. how much more to baffle it for efi (external fuel pump)
